"EMGCY DRIVE" dash light? 79' cj7 - JeepForum.com
post #1 of 22 Old 01-14-2013, 03:51 PM Thread Starter
minipunch
I am wondering if any of you can tell me what one of the very few cj7 dash lights means. It says "EMGCY DRIVE" and is red when illuminated. It will alternate between illuminated on not illuminated frequently but usually is stuck on. It is on the bottom right of the circular glass housing the speedometer.
What is this?!? I have attached a picture
minipunch is offline
post #2 of 22 Old 01-14-2013, 03:56 PM
Coiz
1979 CJ7
It is basically the 4x4 light to let you know when it is in four wheel drive.
Mike
Coiz is offline
post #3 of 22 Old 01-14-2013, 04:24 PM
CSP
Emergency drive is only on the '76-79 CJ7s with an automatic transmission and the Quadratrac tcase.
CSP is offline
post #4 of 22 Old 01-14-2013, 04:27 PM
skizriz
1978 CJ7
And you don't want to be driving on the street with it in E-drive.
You need to find out if it actually in E-drive,or a faulty signal.
skizriz is offline
post #5 of 22 Old 01-15-2013, 01:19 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I'm going to wire mine to the switch on the D300 to light it up, since it is there, the switch is there, and I can do it. Originally the D20 didn't have a switch or anything to do that with.
Rick
Cutlass327 is offline
post #6 of 22 Old 01-15-2013, 03:12 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yep that's what I did also.
John Strenk is offline
post #7 of 22 Old 01-15-2013, 08:36 AM
lucdog
1980 CJ5
John, it's my understanding the switch in the transfer case goes to ground when in E-drive on the Quadratrac. Same for the Dana 300, am I correct on this.
So if in fact this is correct, and the OP's light is flashing, the switch is possibly bad, the wire is grounding out somewere, or it is in E-drive and the connection is loose at the transfer case, causing a intermittent light.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #8 of 22 Old 01-15-2013, 08:51 AM
jumbojeepman
1976 CJ7
Being that I see a shifter lever in the pic, I'm guessing that he actually doesn't have a Quadratrac transfer case.
jumbojeepman is offline
post #9 of 22 Old 01-15-2013, 09:11 AM
John Strenk
1976 CJ5
Bill
Yes You are quite correct.
post #10 of 22 Old 01-15-2013, 09:22 AM
lucdog
1980 CJ5
Thanks John.
So for the OP, I would check the wiring under the hood for the IIRC orange wire on the passenger side. It normally has a fabric sheath around it. My guess is its just hanging somewhere and rubbing on the frame or tub.
In order to run the light off a switch in the dash, like others have done, you would need to find the ground wire behind the speedo for the light. Tap into that wire, and run another up to a switch, then ground the other lug on the switch to a ground point on the dash.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #11 of 22 Old 01-15-2013, 12:36 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Do either of you have a wiring diagram of this system and or at least one with a D300? I have yet to dig into it, one of my low priority "to do" items, but a diagram to see how AMC did it would be handy to have. I do have a FSM wiring diagram for a 78 though, but it would still have the D20 wiring.
Rick
post #12 of 22 Old 01-15-2013, 08:01 PM Thread Starter
minipunch
Thanks for the responses guys! I will have to look into it with this new knowledge!!
post #13 of 22 Old 01-15-2013, 09:43 PM
BagusJeep
1981 CJ7
Mini,
If you fill in your Profile the answers will be more specific. Still wrong but specifically wrong!!!!
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #14 of 22 Old 01-15-2013, 10:34 PM
lucdog
1980 CJ5
Originally Posted by BagusJeep
Mini,
Would you care to be more Specific on what exactly was wrong with any of the posts in this thread.
Cutlass, sorry, I don't.
Bil
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #15 of 22 Old 01-16-2013, 07:58 AM
John Strenk
1976 CJ5
Specifically I think he was being facicious meaning the even if you give all the details of your jeep, we could still give you the wrong advice, it will be 'specifically' wrong for your year not just generally wrong.
