Electrical woes/ '63 CJ-3B - JeepForum.com
post #1 of 1 Old 01-31-2011, 07:00 PM Thread Starter
Goosedog
1963 CJ3B
Here's the symptoms. Motor purrs like a kitten while cold and for the first 30min after it gets up to full operating temperature. Then she starts to cut out whenever motor is taxed. If I try and shift gears and accelerate like normal up to a cruising RPM, it coughs, sputters and dies. Once I pull over and restart, it's good for another 100yrds and dies again. If however, I drive at the lowest RPM possible it stays smooth enuf to get me back home, albeit at 15mph.
I had a dirtbike do this once and it turned out to be the coil. It always tested okay cold but once it heated up the plastic parts would expand and create disconnections within.
Can someone explain the various electrical components in the spark sending circuitry and give their best guess which is the most likely one to go out? Also the battery, distributor, plugs and plug wires are all new. The shop that had the jeep briefly before I did put in those parts. The only electrical I've done is clean up and/or replace what looked worn out in the way of wires and connections.
Thanks, Goose
Goosedog is offline
Electrical Woes - Draining Battery 79BlackPearl Jeep CJ Forum 10 05-21-2008 02:32 PM
Electrical woes MadtownCJ Jeep CJ Forum 12 04-07-2008 08:06 PM
CJ HEI Woes dpete Jeep CJ Forum 8 03-16-2008 12:05 PM
304 Woes Scuffy Jeep CJ Forum 8 02-16-2008 02:45 AM
Electrical Woes cj7roaddog Jeep CJ Forum 2 06-08-2007 07:14 PM
