Electrical Woes - JeepForum.com
post #1 of 3 Old 06-08-2007, 02:54 PM Thread Starter
cj7roaddog
1979 CJ7
Electrical Woes
I know theres been a thousand threads on this problem and I've read through as many pertaining my situation as possible but I an figure this out.
I just put in a painless engine compartment harness using the original fuse block. I had to make some minor adjustments but it work out ok, I think. Anyway, after installing the harness the battery went dead the next day. Tried to charge it and it wouldn't take a charge. So I went down and got a yellow top and put it in. Fired right up. Great, I thought. The next day the brand new battery was dead. So I went through all the battery connections from pos to neg and took them off and clean them really well. Took the ground off from the battery neg to the block, block to frame, battery neg to dash, and cleaned them really well. Took that battery out of the equation and used my F150 battery using jumper cables to start it... nothing. So being that some of the electrical components are a little tired I went down and bought a coil and solenoid. Came back put them in and the solenoid is just clicking.
I can't figure this out. Any help would be appreciated.
1979 CJ7 I6 (Fresh motor) - T18A Tranny - Dana 20 Transfer - CV Driveline - Dana 30 Wide Axle - AMC 20 Wide Axle - 410 Gears - 33" Tires - 4 1/2 Rubicon Lift - ARB Front Locker - Detroit Rear Locker - Custom Cage
cj7roaddog is offline
post #2 of 3 Old 06-08-2007, 03:31 PM
4.7stroker
Some where in your wiring you have a constant current draw.
Get your hands on a clamp on ammeter.
with the ignition and everything else off put the ammeter on the + battery cable there should be zero current draw.
If there is any current draw start pulling one fuze at a time when it drops to zero you have found what circuit is drawing current then all you have to do is find out why.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 3 Old 06-08-2007, 07:14 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
You probably either wired up the alternator to where it is always trying to charge, or you wired up the coil to where it is always trying to fire.
My '70 CJ5 Build Thread:
jayhawkclint is offline
Electrical Woes - Draining Battery 79BlackPearl Jeep CJ Forum 10 05-21-2008 02:32 PM
Electrical woes MadtownCJ Jeep CJ Forum 12 04-07-2008 08:06 PM
304 Woes Scuffy Jeep CJ Forum 8 02-16-2008 02:45 AM
Oil woes 84 CJ7, 258 jayjay Jeep CJ Forum 11 01-31-2008 09:14 AM
AMC 20 Woes turbogus Jeep CJ Forum 6 11-04-2005 09:44 AM
