Electrical Questions - JeepForum.com
post #1 of 2 Old 12-25-2008, 12:18 PM Thread Starter
akdanny
1981 CJ7
First off, I am grounding all my accessory switches to the inside of my cab (body), is that ok? Where should I be putting the grounds (7 of them)? Also, recently my alternator is going down to 11 volts at the stop light, but back up near 14 when driving. Is that the beginning of the alternator going out?
all responses are very appreciated, Dan
akdanny is offline
post #2 of 2 Old 12-26-2008, 12:30 AM
JeepHammer
Running On Empty...
1973 CJ5
Yes, you can run all the dash and switching grounds to one place, just remember to run a wire from there to the battery or primary ground!
Doesn't do them any good to all be together if that panel isn't getting ground!
No, alternator isn't going out, probably the ground to the alternator, (Through engine, brackets, ect.) is loose, or you have a problem with the placement of the 'Sense' wire to the regulator.
VERY common with these old CJ's!
(Easy to fix too!)
Could also be things like stretched, worn belt, worn out pulleys (if the 'V' sides aren't straight, but bowed out '( )', then the pulleys are shot)
Belt was never intended to reach the bottom of the 'V', if the center of the pulley is polished, then the pulley or belt (or both!) are worn out!
Like one of the other guys here is fond of saying,
"Mud is liquid sand paper!",
So if you do a lot of mudding, expect the belts to go every year, and pulleys to go about every three years...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
Electrical questions and 1 "what's this" LawMan02 Jeep CJ Forum 5 01-11-2009 05:55 PM
Couple more questions for the pre-start rundown, ignition, carb, misc questions..... Blthomas Jeep CJ Forum 3 07-01-2008 05:56 AM
Pulled The Dash...Some Electrical Questions Oily Jeep CJ Forum 10 03-25-2008 11:43 AM
several questions, one fan, a few electrical one fuel outdoordad@comc Jeep CJ Forum 3 12-08-2005 11:52 PM
electrical questions cityofcompton3 Jeep CJ Forum 5 07-24-2005 03:21 PM
