electrical questions - JeepForum.com
post #1 of 6 Old 07-24-2005, 12:49 PM Thread Starter
cityofcompton3
77cj7 v8 360 engine
Alright i am already regretting not going with a painless wiring kit, I went with some other company which i have found is not nearly as good as painless can boast. Anyway, i did taillights, headlights, and all that goes with that. I have the dash, steering wheel, and the engine compartment more or less to wire. (Yes i know i did the easy part first). Anyway here are my several questions...
I attempted to start the engine compartment next and have run into several differences in my wiring harness to the wiring that is existing in the jeep. First, i cannot find my voltage regulator, (are those part of the ignition control pack?)
Second, i am having a hard time figuring out what the wires that come out my ignition control pack are all for, i trace them to where they go and am still a little confused, one appears to be a ground (black wire), one power (red wire), another set is sent to the distributor, and there is a final wire (light blue) which appears to go to the solonoid but i don't get what it is for any help? Does anyone have a diagram that tells what the wires coming out of the ignition control module does?
Finally, i have a wire in my harness labeled the alternator excitor wire. I have on clue where this wire goes and am a little confused to say the least, is this wire necissary if there is already a power wire going to the alternator.
(anyone have a suggestion on a book i could buy that breaks wiring down relatively simply?)
i guess those are my questions for now, thanks
cityofcompton3 is offline
post #2 of 6 Old 07-24-2005, 01:35 PM
Rockram1
Chiltons or a Haynes manual should have the schematics your looking for. As for the voltage regulator I believe it's built into the alt. I'm not home now or I'd look it up. What years did the harness you have cover?
I'm getting ready to put a painless in my CJ5 as part of the restoration.
86 CJ7, 258, t18, D300, D44's 4.56's, Detroit front, Warn shafts and CTM joints, spool rear, SOA, SRS, waggy springs, 6 point cage, Warn winch, 38" Tsl, Allied beadlocks.
Rockram1 is offline
post #3 of 6 Old 07-24-2005, 01:43 PM Thread Starter
cityofcompton3
i am not positive the years it covered i know it was good for a 77 which i have. Smart man for buying the painless i hear they are elite. Way better than what i am trying to use right now. Thanks for the regulator answer. Anyone else have any suggestions about the rest of the questions i asked. I have looked at a Chiltons and Hanes manual and can't find answers to the other questions i asked.
thanks
post #4 of 6 Old 07-24-2005, 01:59 PM
Geer_hed
Geer_hed's Avatar
What kind of alternator do you have? If you have a Delco Remy 10/12SI, it's internally regulated.
They all have a purpose, also, not your ingition "pack", rather ignition "module". Didn't know what you were saying until you started naming wire colors.
RED - hot in ON and START - from ignition switch to ignition module and starter solenoid I terminal
BLUE - hot in START - from ignition switch to ignition module and starter solenoid S terminal
BLACK - to distributor (terminates at cap base plate screw) - it is GROUND
PURPLE - to distributor - spark out signal from pickup coil
ORANGE - to distributor - spark in signal from pickup coil
GREEN - to ignition coil - terminal - ignition coil primary ground
Run it to a switched ON B+ source. It energizes the alternator field and tells it when to start charging. See the alternator link above.
85 CJ7 / 258 / T176 / Dana 30/ AMC 20
Geer_hed is offline
post #5 of 6 Old 07-24-2005, 02:53 PM Thread Starter
cityofcompton3
wow, thanks i think that i can handle it from here....though i have to say be ready for more questions as i make my way along this project.
as i am just a novice when it comes to this....
post #6 of 6 Old 07-24-2005, 03:21 PM
gumby
gumby's Avatar
painless wireharness instructions can be downloaded I know you dont have that kit but the wire diagram is the best when trying to figure out the wiring. hanes manual are hard to read
1984 CJ-7 offroad special loves to get dirty and play rough. unlike the girls I meet
258 rebuilt with torquer cam/ weber 32/36 carb, HEI ignition ,headers 4 in lift AMC 20 detroit rear locked and trussed / tru trax front 4:56 Gears ,solid axles on 35's
"Two roads diverged in a wood and I - I took the one less traveled by, and that has made all the difference."-
Robert Frost
gumby is offline
Electrical questions and 1 "what's this" LawMan02 Jeep CJ Forum 5 01-11-2009 05:55 PM
Electrical Questions akdanny Jeep CJ Forum 1 12-26-2008 12:30 AM
Couple more questions for the pre-start rundown, ignition, carb, misc questions..... Blthomas Jeep CJ Forum 3 07-01-2008 05:56 AM
Pulled The Dash...Some Electrical Questions Oily Jeep CJ Forum 10 03-25-2008 11:43 AM
several questions, one fan, a few electrical one fuel outdoordad@comc Jeep CJ Forum 3 12-08-2005 11:52 PM
