Electrical question. I think i have a short. - JeepForum.com
post #1 of 8 Old 06-08-2013, 06:57 PM Thread Starter
Jeeper44mag
1978 CJ7
Ok, here are the symptoms. Whenever I turn on either the parking/running lights, or the headlights, all my dashboard/instrument lights & gauges die and I have no lights of any kind. Not even brake lights or turn signals.
The engine runs just fine regardless, but in neither position, running or headlights, do I have either running or driving lights, or any lights or gauges. Even the stereo loses power.
As long as I don't engage the lights, I have all instruments/gauges, turn signals, brake lights, etc.
I am certain that the light switch assembly is not the issue since I just replaced it with a new unit, and still have the same problem.
Any ideas where I should start looking for a short? Or is it likely to be some other issue?
Thanks in advance,
Luis
Thanks in advance,
Jeeper44mag is offline
post #2 of 8 Old 06-08-2013, 07:04 PM Thread Starter
Jeeper44mag
1978 CJ7
Oh yeah.... '78 CJ7, 304, mostly stock except for~3" lift and 12.5x33 BFG's.
Luis
post #3 of 8 Old 06-08-2013, 07:09 PM
LumpyGrits
YUP, you sure do
What wiring mods have you done??
Check the wiring loom that goes over the brace above the steering col behind the dash.
The sharp edges on the brace cuts through the wiring with ease.
Wrapped mine, with a hose.
The light switch that AMC used was NOT the best either.
LG
LumpyGrits is offline
post #4 of 8 Old 06-08-2013, 07:38 PM Thread Starter
Jeeper44mag
1978 CJ7
No wiring mods that I am aware of. Thanks for the tip, I'll check the wiring over the steering column tomorrow and see if there are any obvious abrasions.
Luis
post #5 of 8 Old 06-09-2013, 09:36 AM
texasdave
texasdave's Avatar
1980 CJ7
Dimmer switch on the floor can cause all kinds of weird things to happen and with all the dirt water over the years well you know the rest.
texasdave is offline
post #6 of 8 Old 06-09-2013, 12:39 PM
robs7
1983 CJ7
Check all of your grounds. Bad grounds can cause all kinds of mysterious things to happen. Rob
robs7 is offline
post #7 of 8 Old 06-09-2013, 06:15 PM
Bubba Ray
Try the grounds for the parking lights. They ground with the screws that hold them to the grill. If this is the problem then solder wire to the back of the housings and run wires to a ground.
Bubba Ray is offline
post #8 of 8 Old 06-10-2013, 02:49 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Sounds like your dash is not grounded. When the lights are off, the current finds a path to ground through the parking light filaments but when the lights are ON then the path to ground is blocked.
John Strenk is offline
