electrical problem WTF??? - JeepForum.com
post #1 of 8 Old 07-12-2014, 09:27 PM Thread Starter
spottedfrog
1979 CJ5
So I parked the Jeep for the night. I just looked out side the window and the taillights were illuminated! the ignition is off, the headlights are off the volt meter is at zero. nothing is on except the tail lamps.
this is the 1st time this has ever happened.
I disconnected the battery so the Jeep wont catch fire tonight.
Where do I even start to track down the problem. Electrical is my weak point for sure.
spottedfrog is offline
post #2 of 8 Old 07-12-2014, 10:03 PM
Kstein
thinking out loud.....
I think the backup lights and/or the brake lights are on an always-hot circuit (not controlled by the ignition switch.)
Could the brake light switch be bad?
TAMC85 CJ7
Still Original: Tub, Rollbar; Frame; 258 Block; T176; DANA300; Steering; DANA30; AMC20; Drive Shafts; Wheels; Tank; Altenator; Fan; Frt Bumper; Speedo; Heater Box; Spare Carrier; Seat risers
Replaced: Radiator; Valve Cover; Clutch linkage; Taillights; Frt Brake Calipers; Fuel, Tmp, and Oil Pressure Gauges; Exhaust line; Seat Belts; Paint
Mods: Mopar MPI(in progress); 4.0 Al Cylinder Head; OME YJ Suspension; MC Seats; Tub liner; 31" Tires
Kstein is offline
post #3 of 8 Old 07-12-2014, 10:29 PM Thread Starter
spottedfrog
1979 CJ5
Could be its 34 years old.
post #4 of 8 Old 07-16-2014, 04:28 PM
carnuck
1984 J-Series Truck
Someone install a stereo incorrectly?
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #5 of 8 Old 07-16-2014, 04:51 PM
lucdog
lucdog's Avatar
1980 CJ5
thinking out loud..... I think the backup lights and/or the brake lights are on an always-hot circuit (not controlled by the ignition switch.) Could the brake light switch be bad?
Or just need to be adjusted.
And it's the brake lights.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #6 of 8 Old 07-16-2014, 05:41 PM Thread Starter
spottedfrog
1979 CJ5
No stereo. It has never done this before, so the adjustment shouldn't have been an issue. I swapped out the switch and so its ok. BUT it was fine previously too....time will tell I guess.
post #7 of 8 Old 07-16-2014, 06:01 PM
lucdog
lucdog's Avatar
1980 CJ5
:-) everything is usually fine till it breaks or wears out
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #8 of 8 Old 07-16-2014, 06:55 PM
zillla
1930 VJ
Could it be a reflection or light shining in the tail lights? These things can be a real pain to track down. I'd start with an OEM wiring diagram and chase it out. Otherwise I'd start at the light switch
Pull my finger
zillla is offline
