Electrical problem!! i need help! - JeepForum.com
post #1 of 6 Old 11-14-2002, 06:24 PM Thread Starter
cj5mudman4x4
My 73' Cj5 has been being rebuilt for about a year now, i have rebuilt the engine, put a new alternator on, new coil, new battery, new solenoids, new cables, almost everything to do with the battery. a new exhaust manifold, just countless things! now i was driving to town and it did fine, besides steering, thats another story, when i got to where i was going i did my thing and i got ready to go and my jeep wouldnt even try to turn over, absolutely nothing. it had done this before, but a new battery fixed it right up. i gave it a push start and was on my way. while i was driving the headlights would get dim and go out (scary on a country road at night!) then my jeep would die! it did this 2 times on the way home! i got home and put the charger on it and it hasnt acted up since! WHATS GOIN ON??
1973 CJ5
258ci I6 rebuilt. bored .40
Painless wiring harness
INDEPENDENT OFFROAD member Bowling Green, Ky
cj5mudman4x4 is offline
post #2 of 6 Old 11-14-2002, 08:03 PM
bowhunter
sounds like the alt not charging the battery
bowhunter is offline
post #3 of 6 Old 11-14-2002, 08:47 PM
Big Bill 33
It does sound like the Alt or it could be a loose ground wire also. Just because it's new does not mean it cannot be bad. Good luck.
Bill Green
Big Bill 33 is offline
post #4 of 6 Old 11-14-2002, 09:41 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Odds are the brushes in the Ford style starter are bad. Drop the starter and take the back off. I'll bet the brushes are worn down and the brush arms are contacting the armature raising the brushes off the commutator.
jeepdaddy2000 is offline
post #5 of 6 Old 11-14-2002, 09:51 PM
jeepdaddy2000
1971 CJ5
Silly me, I didn't read the second half of your post. It sounds like a charging problem. Check all conections between the alt. and batt. If the problem is intermitant, try replacing the voltage regulator. You also might want to inspect your wiring harness for shorts, especialy around the exhaust.
post #6 of 6 Old 11-15-2002, 07:40 AM
jrejle
I had similar problems with my 74 CJ5. I pulled the wire connector going to the voltage regulator off and rebuilt the connector. I havent had a problem since then.
jrejle is offline
electrical problem idaho elk Jeep CJ Forum 1 05-03-2008 09:58 PM
CJ7 Electrical Problem mcdaddytx Jeep CJ Forum 9 01-02-2006 06:18 AM
Electrical Problem pf1130 Jeep CJ Forum 23 12-01-2005 04:32 PM
Another CJ 7 Electrical Problem nozzleram Jeep CJ Forum 10 02-05-2005 08:29 PM
electrical problem v75vette Jeep CJ Forum 1 05-31-2004 11:39 AM
