electrical problem - JeepForum.com
post #1 of 2 Old 05-31-2004, 09:39 AM Thread Starter
v75vette
electrical problem
I've got an 85 CJ7 with a 6cyl. the only real mod we've done to it is the blower moter upgrade. I was going down the road one morning had my lights on and turned the blower on and it started to sputter and die, turned the blower off and it ran fine. Regularly it runs at about 14 amps, when you turn the lights on it drops to 13. the problem comes when you turn the lights on and then go to turn the heater on. As you do this the amps drop to about 10 and then climb back up to 11. I can have both on at a stop light or something and it will want to stall as i go. Any suggestions on how to fix this?
v75vette is offline
post #2 of 2 Old 05-31-2004, 11:39 AM
slickwillie
slickwillie's Avatar
First thing I would look at would be grounds. Make sure they're all clean & tight, if that doesn't work, start tracing wires to see if you have a short somewhere. Good luck.
1983 CJ7 AMC 360, T-5, Dana 300, Dana 30, AMC 20
Warn XD9000i, RE hand throttle, 1" body lift, OBA
slickwillie is offline
electrical problem idaho elk Jeep CJ Forum 1 05-03-2008 09:58 PM
CJ7 Electrical Problem mcdaddytx Jeep CJ Forum 9 01-02-2006 06:18 AM
Electrical problem?! Please help!! Johnny5 Jeep CJ Forum 4 12-07-2005 03:51 PM
Electrical Problem pf1130 Jeep CJ Forum 23 12-01-2005 04:32 PM
Another CJ 7 Electrical Problem nozzleram Jeep CJ Forum 10 02-05-2005 08:29 PM
