Quantcast Electrical/Battery/Alternator Issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Electrical/Battery/Alternator Issue
RUBICON EXPRESS Lift Kits and Accessories Available at BasTruck-Lite's New LED Headlamp SeriesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 02-09-2008, 07:53 PM   #1
hoezaycuervo
1978 CJ5
Hey guys, first post and new Jeep owner. I bought a 78 CJ-5 w/ 304 in January hoping to not have to do a lot and slowly learn since its my first jeep and i'm getting into it now.
This week the volts slowly dropped during mid drive and eventually it wouldn't start. Took out the alternator and had it test, bad, so replaced it. Then I jumped the jeep off w/ my car and it ran fine, a little rough, but fine for about 10 min idling. Then I cut off and tried to restart, it struggled so i dumped clutch and it ran, but was misfiring and voltage was barely registering, so I assumed bad battery. Charged/tested/replaced battery expecting it to fire right up with new one and now when I turn the ignition, the lights come on but nothing happens, no click, no effort by the motor to turn over.....i'm lost as to what to do from here. Could the solenoid have been ruined?
hoezaycuervo is offline   Reply With Quote
Old 02-09-2008, 08:18 PM   #2
4.7stroker
4.7stroker's Avatar
**CAUTION**
Remove the neg cable first and reinstall it last, this will prevent any possibility of a short
**CAUTION**
Remove both ends of both battery cables.
Using a wire brush clean the mating surfaces and the cable ends.
The surfaces must be bright and shiney.
Remove the wires from the starter relay clean connections and reinstall.
Remove wires from alternator clean connections and reinstall.
Reinstall battery cables.
All should be well providing there are no other problems.
Dwayne
4.7stroker is offline   Reply With Quote
Old 02-09-2008, 09:57 PM   #3
CJhollic
1980 CJ7
if 4.7's advice doesnt work, try jumping it across the solenoid. If it works, chances are your solenoid is bad.
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline   Reply With Quote
Old 02-10-2008, 07:56 AM   #4
hoezaycuervo
1978 CJ5
Thanks for the input. I rewired the alternator with brand new wires, but will check the starter/battery and clean them up. How do I jump start with the solenoid? I have a 4 post.
Old 02-10-2008, 10:24 AM   #5
hoezaycuervo
1978 CJ5
I double checked and cleaned my connections and everything should be good. When I laid a screwdriver across the top 2 post nothing happened (ignition was in "run" position). Did I do that correctly? I have the positive terminal from battery, positive cable and 1 field cable from alternator on left side, starter cable on right, nothing on the I terminal, then a greenish blue cable on the S terminal. This is how it was wired when I bought it and it ran. The solenoid looks to be pretty new.
Old 02-10-2008, 11:03 AM   #6
CJhollic
1980 CJ7
With the jeep in park or neutral and the emergency brake on, turn the ignition to the midway position or "run".
With 2 screwdrivers or a pair of channel locks, short the two big posts. One comes from the battery, the other the starter.
This will turn the engine over and send voltage to the coil.
It sounds like you did it right. What happens when you do this?
If nothing, check the connection at the starter and the negative cable at the engine block.
At that point it narrows it down to a couple of things, bad starter or bad or uncharged battery.
Weber 32/36 DGEV,
8000 lb Winch,
ViAir Onboard Air
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Mile Marker Hubs
Old 02-10-2008, 02:27 PM   #7
hoezaycuervo
1978 CJ5
I finally fixed it....I think. My new neighbor came over and tested to find out my coil was stuck "open" so that the starter was always receiving power, which pretty much burned it up. I replaced the solenoid and starter and it fired right up. Thanks for the help guys!
Now...the new alternator is putting out 16V+ maxing out my gauge....should I install a resistor or regulator to tone it down or will it break in and be ok?
Old 02-10-2008, 02:53 PM   #8
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Does the alternator have a warranty? Running a new alternator on a dead battery can kill it and void some warranties. A friend got a big green alternator or some such thing and I read that in the warranty sheet.
16 is far too high. I think I would check it with a multimeter on the back of the alternator to be sure.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Old 02-10-2008, 07:49 PM   #9
hoezaycuervo
1978 CJ5
I actually replaced the battery as well through this process, so my electrical system is essentially brand new other than wiring. The only drain the new battery saw was trying to crank with the bad solenoid and starter.
Old 02-11-2008, 09:33 AM   #10
Mike Romain
Off Road Forever
Well.... I was meaning this statement:
Took out the alternator and had it test, bad, so replaced it. Then I jumped the jeep off w/ my car and it ran fine.
And then: but was misfiring and voltage was barely registering.
For your second start which implies to me the alternator might have gotten smoked when you first put it in on the dead battery.
It happens. I would be testing the alternator before progressing to other things.
Mike
Glock Forum
