Electric Plenum Heater - JeepForum.com
post #1 of 7 Old 09-23-2011, 10:42 AM Thread Starter
swatson454
1983 CJ7
Once again, the search function isn't my friend. Can one of you guys tell me what water temperature the electric heater on the floor of the manifold is supposed to cut off at? California emissions-equipped '83 CJ7, 4.2L
Thanks!
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #2 of 7 Old 09-23-2011, 10:59 AM
86cj74.2L
86cj74.2L's Avatar
Around 160 I believe.
86cj74.2L is offline
post #3 of 7 Old 09-23-2011, 11:12 AM
mcmud
1983 CJ8
Thats the number.
mcmud is offline
post #4 of 7 Old 09-23-2011, 11:34 AM Thread Starter
swatson454
1983 CJ7
Thanks guys
Shawn
post #5 of 7 Old 09-23-2011, 10:07 PM
86cj74.2L
86cj74.2L's Avatar
relay is on the firewall hanging out of the harness nere the mastercylinder.
If heater isn't working look at the relay first, You can follow the big gauge wire to the heater element to conform you have the correct relay.....orange or red with white stripe....I forget.
post #6 of 7 Old 09-24-2011, 09:01 PM Thread Starter
swatson454
1983 CJ7
Nope, it isn't. I'm pretty sure it used to but it ain't now. I removed the water heat from the manifold and ran it for a week or so before I remembered to disconnect the plenum heater so I may have killed it, assuming that will kill it.
The relay looks like it puked something caustic out of it so I'm guessing it's dead.
Thanks for the help.
Shawn
post #7 of 7 Old 09-24-2011, 10:21 PM
86cj74.2L
86cj74.2L's Avatar
Yea, mine looked bad as well. That relay is sort of special. Try and cross the part number on the relay. Do not just grab one off the shelf.
The relay is energized by the temp sensor. And the sensor is not a on off switch. So as it's resistance changes the output voltage goes up to a point the relay will "pull in" the make and break voltages are a little lower/different then your off the shelf automotive relay.
Heater upgrade: What did you do with factory intake plenum? PortlandCJ76 Jeep CJ Forum 6 09-22-2013 02:54 PM
Plenum Needed??? Pink-Monster Jeep CJ Forum 3 05-04-2011 12:36 PM
Electric Choke and Manifold Heater Wiring for 258 ChaseB Jeep CJ Forum 19 11-14-2010 07:05 PM
Missing Wires - Heater Moter & Electric Choke KBONSIG Jeep CJ Forum 0 10-13-2008 10:21 AM
removing defrost plenum gwalls Jeep CJ Forum 12 08-11-2006 11:30 AM
