Electric with a mechanical fuel pump? - JeepForum.com
post #1 of 5 Old 10-23-2009, 11:01 AM Thread Starter
Hybrid Jeep
1976 CJ5
Hey guys.. I'm at the stage of my build where I can easily put an electric fuel pump in line with the factory mechanical fuel pump. Can anyone think of any problems with this? The mechanical pump will have to pull through the electric... with the electric only being used as a back up.
Hybrid Jeep is offline
post #2 of 5 Old 10-23-2009, 11:13 AM
way_of_life
1978 CJ7
I have the mechanical one up front and an electric one in the back by the tank-- I had some circuit problems with it at first but that's probably because of the way some idiot re-installed the wiring harness years ago.
I have the electric one on a circuit I made completely seperate with its own little fuse block and I have it on for a few seconds before starting the engine and the entire time it's running.
If yours is like mine (304) and sometimes needs a little help on a cold start, the extra pump will help A LOT plus you can still gas it a little upon start-up if needed.
°lllllll°
way_of_life is offline
post #3 of 5 Old 10-23-2009, 11:15 AM
way_of_life
1978 CJ7
Just to make sure this part is clear--- My electric one is in line before the mechanical one.
°lllllll°
post #4 of 5 Old 10-23-2009, 11:16 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
It can cause a restriction, making it harder for the mechanical to pump. I think you should just sticck with the mechanical if you aren't going EFI. With mechanical, you have less wiring to worry about, the fuel stops as soon as the enigne stops (electric you should use an oil psi switch for this purpose), and they are not all tha failure prone in my experience. Electric you have to orry about protecting wires, loose connections, pressure regulator, etc. More of a hassle to me.
Rick
Cutlass327 is offline
post #5 of 5 Old 10-23-2009, 05:10 PM
jfwireless
1976 CJ7
Before I went TBI I installed an electric pump, worked great and in a CJ would never go back to a mechanical one. I bypassed my mechanical pump, there was just no need for it. Used a small block Chevy plate to clode up the mechanical port.
Jim
jfwireless is offline
Swapping a mechanical fule pump for an electric?? NHwheelin Jeep CJ Forum 11 01-04-2010 04:52 AM
amc 360 mechanical fuel pump issue JKM3134 Jeep CJ Forum 1 08-28-2009 07:23 AM
Installed new mechanical Fuel Pump and now it gets no gas dongogolf Jeep CJ Forum 8 08-01-2009 08:17 PM
Mechanical fuel pump for a 304 Totallymetal Jeep CJ Forum 5 01-28-2009 01:20 PM
Replacing Mechanical Fuel Pump MikeCJ7 Jeep CJ Forum 4 01-09-2006 03:05 PM
