Electric Fuel Pumps (carbureted) - JeepForum.com
post #1 of 12 Old 11-09-2011, 08:44 AM Thread Starter
RENEGADECJ-7
1980 CJ7
Who likes electric fuel pumps for carbureters? What kind and where do to mount them? The crossmember in front of the gas tank seems the most protected place but mounts the pump at the top level of the tank.
RENEGADECJ-7 is offline
post #2 of 12 Old 11-09-2011, 10:24 AM
AFRd_CJ5
1976 CJ5
I've had a few on mine. First one was a Holley red pump, then I had a BG 220HR pump. Crude setup with a bung welded into the tank
Since the, I've changed again to an Aeromotive A1000 and sumped the tank.
Here you can see my return line setup
And regulators
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline
post #3 of 12 Old 11-09-2011, 10:39 AM
SuperSportCJ
1982 CJ7
I have this one along with a pressure regulator on my 304 with a holley 470 and it works great even in the coldest or hottest of temps. Its quiet too unlike some pumps. I have it mounted with a fuel filter on the cross member that you mentoned and never had an issue with fuel delivery.
http://shop.advanceautoparts.com/web...3-2#fragment-2
SuperSportCJ is offline
post #4 of 12 Old 11-09-2011, 10:44 AM
SuperSportCJ
1982 CJ7
I also have a fuel cutoff switch wired under my dash which is nice when trying to drain the carb, for safety, or even as an antitheft device
post #5 of 12 Old 11-09-2011, 10:47 AM Thread Starter
RENEGADECJ-7
1980 CJ7
How long have you had the airtex pump? I looked at those and wondered how well they hold up. A local mechanic I talked to said external pumps just don't last long. I would want something quiet and reliable.
post #6 of 12 Old 11-09-2011, 11:14 AM
SuperSportCJ
1982 CJ7
I've had my jeep for a little over 3 years now and it hasnt let me down yet. I rebuilt the engine last fall with larger Comp Cams cam, Edelbrock intake, Holly TA 470, Edelbrock Shorty headers and the Team Rush upgrade. It delivered fuel no problem before and after the rebuild. I drive it daily in winter and a couple times per week in summer.
post #7 of 12 Old 11-09-2011, 01:03 PM
mopar408
1974 CJ5
Arrested for impersonating a mechanic...
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #8 of 12 Old 11-09-2011, 01:04 PM
AFRd_CJ5
1976 CJ5
We've been running an Aeromotive A1000 on dads Jeep since '06. My A1000 has been on since '08. Never a problem.
I've also got a cutoff switch "somewhere" on my Jeep for a little anti theft security :-)
Just keep in mind, most pump manufacturers want the pumps mounted as close to the tank as possible, and at least at the 1/2 way or lower mark of the tank (most are gravity fed, and you can get priming/pressure issues, as well as burn the pump up).
'76 CJ5
AFRd_CJ5 is offline
post #9 of 12 Old 11-09-2011, 07:05 PM Thread Starter
RENEGADECJ-7
1980 CJ7
Thanks guys. Anyone else?
post #10 of 12 Old 11-09-2011, 07:12 PM
Foundrydude
Carter electric street pump. Sold at napa as a federal mogul pump using the same part number as Summit, it'll even come out of the federal mogul box wearing a carter sticker. Your counter guy will be amazed after he swears they don't have it.
Been using them for over 20 years with an excellent reliability record, everything from stock motors to hot 400hp V8s. My buddies with holley pumps and airtex pumps all end up with a carter after the others fail. Personally won't install anything else. And they're attractively priced.
Foundrydude is offline
post #11 of 12 Old 11-09-2011, 10:42 PM
BagusJeep
1981 CJ7
Dumped the Denso electric pump and fitted the original mechanical pump after it started cutting in and out. It works as intended with a system that includes the 3 way filter. Totally reliable and one less electrical circuit.
Other CJ still has a Denso electric pump but its days are numbered.
Both electrics worked when mounted in the engine bay just under the brake master cylinder where there is a convenient ledge in RHD next to the incoming petrol pipe.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #12 of 12 Old 11-10-2011, 04:37 AM
AFRd_CJ5
1976 CJ5
That may be why your pump stopped working correctly. Most all electric pumps (I know nothing about the Denso pumps, but most are) are "pushers", meaning they are meant to be mounted as close to the tank as possible, and push the fuel up. They can and will burn up quickly being used as "pullers".
'76 CJ5
AFRd_CJ5 is offline
My new jeep has Two fuel pumps and a bad fuel gauge musclenut Jeep CJ Forum 6 07-10-2011 07:38 PM
Stock fuel psi for electric fuel pump??? TampaXJ Jeep CJ Forum 26 08-30-2010 01:58 PM
electric fuel pumps and a 304 ? unfrgvnw2 Jeep CJ Forum 3 03-08-2010 04:45 PM
Fuel Pumps lastseen Jeep CJ Forum 1 12-07-2008 11:04 AM
AMC V8 Fuel Pumps zslnk Jeep CJ Forum 3 04-11-2005 07:40 AM
