Electric fan Help - JeepForum.com
post #1 of 11 Old 06-01-2009, 10:47 PM Thread Starter
jrylb73
Electric fan Help
Ok, here is my problem, I have an 82 CJ7 with a 4.2L, the person that had the Jeep before me put a eletric fan in it. He had the fan fixed where you could turn it on and off by a switch under the dash, well I had to keep replacing the switch because it would get so hot it would melt the plastic switch, so trying to quick fix it so it would work I bypassed the switch and ran it direct. Now the problem is the wires got hot enough that it melted the inline fuse that comes off of the fan.
Thanks
Jerry Burris
jrylb73 is offline
post #2 of 11 Old 06-01-2009, 10:54 PM
Coiz
1979 CJ7
You should probably wire in a relay to control the fan. The relay would be controlled by the switch and will easily be able to power the fan with the correct wire gauge and circuit protection with no problems.
Mike
Coiz is offline
post #3 of 11 Old 06-01-2009, 11:10 PM Thread Starter
jrylb73
What gauge of wire should be used on this fan. What type of relay are you talking about?
jrylb73 is offline
post #4 of 11 Old 06-01-2009, 11:18 PM
Coiz
1979 CJ7
I would use a 10 gauge wire for the feed and just about any 30+ amp automotive relay will work. It makes it so all of the load goes through the relay and the switch only sees the low current side of the circuit.
You can either part them together or just buy a kit. You could even get one with a thermostat input to control the fan. I have mine on a 3 way switch with an adjustable temp relay. I can have it on, off or thermometer controlled. Click on the instructions link in the above pages if you want to see how they are wired.
Mike
Coiz is offline
post #5 of 11 Old 06-01-2009, 11:29 PM Thread Starter
jrylb73
where is this instruction link located on the above page.
jrylb73 is offline
post #6 of 11 Old 06-01-2009, 11:32 PM
Coiz
1979 CJ7
At the bottom of the description.
Simple kit install.
Thermo control kit install.
Mike
Coiz is offline
post #7 of 11 Old 06-01-2009, 11:36 PM Thread Starter
jrylb73
Does autozone or Orielly's carry something like this?
jrylb73 is offline
post #8 of 11 Old 06-01-2009, 11:45 PM
Coiz
1979 CJ7
The kits, probably. I bought my electric fan and the relay control setup at an Autozone 10 years ago. If your looking to just buy a switch, relay and wires, they will have everything you need.
Just found this on Autozone.com And here is the thermostat controlled one on Autozone.com.
Mike
Coiz is offline
post #9 of 11 Old 06-01-2009, 11:48 PM Thread Starter
jrylb73
ok, I would like to thank you for all your help.
jrylb73 is offline
post #10 of 11 Old 06-01-2009, 11:53 PM
Coiz
1979 CJ7
No problem. Let us know how it works out for you.
Mike
Coiz is offline
post #11 of 11 Old 06-02-2009, 10:23 PM Thread Starter
jrylb73
Well i purchased a electric fan relay kit today. I plan on installing it on Thursday, I will let you know how things went.
jrylb73 is offline
Which electric fan? jeepmor Jeep CJ Forum 11 05-25-2010 11:22 PM
electric fan marmaduke Jeep CJ Forum 1 06-04-2007 11:24 AM
Electric Fan Help jrylb73 Jeep CJ Forum 10 04-17-2007 09:42 PM
Electric fan ? goat24 Jeep CJ Forum 22 04-07-2007 12:54 PM
Electric CJ bayonetblaha Jeep CJ Forum 3 08-06-2006 11:29 AM
