Does anybody run an electric fan on a CJ7 with the 304? I bought a used perma-cool 18 inch electric fan used from a guy. I will have to modify and fabricate the mounts but the fan will fit inside the stock shroud for better flow through the radiator. The fan is rated at 2500cfm. So I am hoping it will work, I am not sure how many cfm is required but I know that it is a pretty powerful fan. Anybody that thinks this will not cool effectively? Thanks for your input.
I'm running about the same thing on mine, works great, just a power hog!
Use a switch on the relay so you can shut it off in cool weather or when you are fording water...
Fans don't like to push water at all!
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
