electric choke vs. manual choke... - JeepForum.com
post #1 of 13 Old 11-11-2008, 07:19 AM Thread Starter
hex
1978 CJ7
i know this topic should be in the engines section of the forum, however, i since i own a '78 CJ7 i am interested in other CJ owners opinions ...
i am rebuilding my AMC 304 V-8. currently it has motorcraft 2150 2 bbl carb with a mechanical choke. the choke is a hard tube that goes into a "choke stove" in the intake manifold. the hard tube is rusted through (no surprise there). i am set on getting a rebuilt 2150/2100 but am debating on going electric choke or manual.
i like the thought of a simple choke cable routed to the dash. on-off... old school; and i know it will always work.
i welcome your opinions
hex is offline
post #2 of 13 Old 11-11-2008, 09:21 AM
buzzbrick
My experience in the matter is on a Holley carb, not the Motorcraft you're looking at, so it might not be quite the same. That having been said, I definitely prefer my manual choke setup- I had an electric choke which I removed and installed the manual choke. It's simpler, and I've just had better luck with it. My cable is set up like you're talking about, with the cable routed through the dash, and so far I like it.
buzzbrick is offline
post #3 of 13 Old 11-11-2008, 09:29 AM
neals80
1980 CJ7
I went manual with my 1980 258 with a Holly 2BBL....I do live in SW Florida so usage is minimal still it gets used and works every time...
Neal Trombley
1980 CJ 7
SW FLORIDA
IF I WANTED A HUMMER I WOULD HAVE CALLED YOUR GIRLFRIEND!!
neals80 is offline
post #4 of 13 Old 11-11-2008, 12:49 PM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
I have a properly adjusted and functioning electric choke on my 304 and I have never had an issue with it in cold or hot weather. The key is to ensure it is properly adjusted for spring tension and throttle plate clearance, and that the electrics are properly hooked up. After that, it is a "install and forget" item....
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
post #5 of 13 Old 11-11-2008, 04:39 PM
zachblamercj7
me too i got my choke adjusted i live in michigan and even on the coldest days before school it alwase starts(even though some mornings i wish it wouldnt) but once i got it adjusted it has never gave me a problem
1986 CJ-7 258 Dana 30 front Dana 44 rear Dana 300 T-case
zachblamercj7 is offline
post #6 of 13 Old 08-17-2013, 08:47 PM
CJ-junky
Manual choke - if you ever go to OBA then it can also be used to pump up the engine idle for a few minutes.
CJ-junky is offline
post #7 of 13 Old 08-17-2013, 08:57 PM
superj
I will always run an electric one over a manual choke because it is one of those things you never have to think about. Once you rebuild your carb and set the choke while installing and adjusting the carb, you never will touch the electric choke again.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #8 of 13 Old 08-17-2013, 09:12 PM
petey156
1977 CJ5
Please explain this...
petey156 is offline
post #9 of 13 Old 08-17-2013, 09:51 PM
lucdog
lucdog's Avatar
1980 CJ5
What he is referring to is using the cable that is usually mounted in or under the dash. The other end is attached to the carb linkage. On board air in this case would run off a engine pulley, think AC compressor. The more RPM's, the faster the air pumps up.
The problem with a choke cable to increase RPM, is that there isn't enough resistance with the cable to overcome the spring on the carb.
Most people use a shifter cable and thumb control from a bicycle , the shift cable can be tightened at the thumb control, to overcome the spring.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #10 of 13 Old 08-18-2013, 06:42 AM
petey156
1977 CJ5
Ok a hand throttle. Thank you, I was over thinking that
petey156 is offline
post #11 of 13 Old 08-18-2013, 08:02 AM
WindKnot
1977 CJ7
A better solution would be to use a hand throttle.
I prefer my electric choke. It is also correctly set. If it wasn't it could be a pain and a manual would be easier. but that would also be treating the symptom as opposed to fixing the problem.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is online now
post #12 of 13 Old 08-18-2013, 06:45 PM
Nereussailor
Mine's manual, been that way for 21 years. Wouldn't have it any other way.
I'm not sure what tomorrow will bring, but it can't be any worse than what I've already been through.
Nereussailor is offline
post #13 of 13 Old 08-18-2013, 08:29 PM
shum8
1980 CJ7
Count me in for the manual....... Never had a problem with it, and if anyone ever tries to steal yer Jeep in cold weather, they probably wouldnt have a clue as to why it won't start
shum8 is offline
Manual vs. electric choke...which is preferred? imtheant Jeep CJ Forum 3 04-07-2009 04:34 PM
getting new carb....electric or manual choke? meatloaf Jeep CJ Forum 3 10-15-2008 07:46 PM
Electric choke JeffJ Jeep CJ Forum 3 09-01-2008 06:38 PM
Manual Choke To Electric???? shelbycj5 Jeep CJ Forum 5 10-01-2007 08:39 PM
Electric Choke Help cj7roaddog Jeep CJ Forum 0 05-11-2007 11:39 AM
