EGR Tube Won't Fit, P/N J3241722 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > EGR Tube Won't Fit, P/N J3241722
TeraFlex Now at Rockridge 4WD! BEST DEALS around!Alloy usa heavy duty ball joint kitsENGO QUADLUX 6" to 54" LED AMBER AND WHITE MULTI
Unread 09-21-2014, 05:19 AM   #1
RoyL11z7
Junior Member
RoyL11z7's Avatar
I got the part thru dealer but it's not even close to fitting, bought a new stock exhaust manifold, so something's wrong with one of them... anybody have to "tweak" their OEM tube to fit?
It'll line up on the exhaust manifold about 3/4" off the center where it should be, that's alot more than "tweaking" to get it to fit. Tried installing it both ways, only one way comes close.
P/N shows J3237776, original CJ p/n crosses to J3241722, they are said to be the same part.
http://www.autopartoo.com/oem/chrysler/j3237776.html
Roy
85 CJ7, 4.2, 4-spd, nuttered
RoyL11z7 is offline   Reply With Quote Quick reply to this message
Unread 09-21-2014, 05:55 AM   #2
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'm not sure what "tube" you are talking about.
Pics of the part would help.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 09-21-2014, 06:31 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Your link doesn't show anything useful. Could you maybe have a YJ one? Don't know if there is any difference, but...
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 09-21-2014, 08:53 AM   #4
RoyL11z7
Junior Member
RoyL11z7's Avatar
Pics of the part would help. Matt
here's a "borrowed pic..." http://www.jeepforum.com/forum/attac...ld-engine2.jpg
Link intended to show the 2 p/ns cross-reference pedigree... the J3241722 is a YJ #, but apparently it is the same thing as the old CJ #J3237776
Roy
Unread 09-21-2014, 09:07 AM   #5
Matt1981CJ7
1981 CJ7
Roy,
OK, now I'm with you.
Unfortunately, I never had to mess with that tube on my 258, so I got nuttin' for ya. Sorry.
Matt
Unread 09-21-2014, 09:29 AM   #6
keith460
Jeep. There's Only One
keith460's Avatar
That EGR tube came in two styles. One was a rigid type that is more difficult to install and a later version was made like a flexible gas pipe so to speak. The later version had the ability to flex more during the heat and cool cycles plus the aluminum intake manifold would expand and contract more than the exhaust manifold.
I don't know where you could get either one but it is advisable to use a copper based anti-seize compound on the threads before installing.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote Quick reply to this message
Unread 09-21-2014, 03:10 PM   #7
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
If you order a new one from Chrysler today it will be the rigid type. I installed a new one on my engine when I gave it a cosmetic makeover.
What I found you have to do is install the tube finger tight to the manifolds BEFORE you attach the manifolds to the engine. Perhaps if you loosen the bolts up it might give you enough wiggle room to work with without having to take the manifolds off the engine entirely.
'85 CJ-7 Laredo currently under construction.
My Rebuild/Restoration Thread, In Progress
BlkCJ7Laredo is online now   Reply With Quote Quick reply to this message
Unread 09-21-2014, 03:36 PM   #8
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Here's the pic, click-free. The part in question is shown encircled in a thin red line:
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote Quick reply to this message
Unread 09-21-2014, 04:26 PM   #9
RoyL11z7
Junior Member
RoyL11z7's Avatar
Thx, that helps. Didn't want to get out the torch prematurely ...
Roy
Unread 09-21-2014, 04:28 PM   #10
RoyL11z7
Junior Member
RoyL11z7's Avatar
Thanks, have trouble getting pics to photo bucket...
Roy
