effect of tires on speed - JeepForum.com
post #1 of 3 Old 08-23-2006, 03:22 AM Thread Starter
T-$$
someone out there have a chart or something handy? I know all about changinging the speedo gears and stuff but i am just curious how far off i am with 35's on my 7 bouncing around town.
T-$$ is offline
post #2 of 3 Old 08-23-2006, 07:32 AM
bdmonist
WTF is that?
bdmonist's Avatar
MPH = (RPM x tirediamter) / (336 x Total Gear Ratio)
Total gear ratio is differential gear x transmission gear x transfer case gear(usually 1)
Tire diameter needs to be measured diameter not advertised.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #3 of 3 Old 08-24-2006, 07:17 AM
1984CJ
1984CJ's Avatar
Here is a link to a site that has a speedo gear calculator on it.
http://www.jeeptech.com/javaAps/Speedo.html
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline
The effect of lifts on your steering, drivetrain, etc. gojeepin Jeep CJ Forum 57 06-30-2012 12:10 PM
Atmospheric Pressure effect on Compression Testing Hybrid Jeep Jeep CJ Forum 4 03-11-2009 01:59 PM
Effect of vacuum leak PaulS Jeep CJ Forum 3 06-05-2008 09:56 AM
How does larger tires effect speedometer and odometer? Lupulin Jeep CJ Forum 5 05-28-2007 02:50 PM
