The effect of lifts on your steering, drivetrain, etc. - Page 4 - JeepForum.com
post #46 of 58 Old 09-18-2011, 04:16 PM
LibertyJeeper
If your pitman arm is the same length <parallel hole to hole> then your steering radius should not change
Originally Posted by walkerhoundvm View Post
Just keep in mind: things are never as bad as they seem. These are jeeps, built by man and any problems you come across can be solved by man - even you! Best of luck.
Looking for axles 4.10's or higher
LibertyJeeper is offline
post #47 of 58 Old 09-18-2011, 05:48 PM Thread Starter
gojeepin
1983 CJ7
Right. My drop pitman arm was shorter and it was a very noticable change. My son's drop pitman arm from a diferent manufacturer was the same length as his stock one.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #48 of 58 Old 09-18-2011, 06:12 PM
skizriz
1978 CJ7
My point is that my arm is noticeable shorter. But it will still go well into the steering stops, and beyond, putting the tires into the leaf springs (without stops adjusted).
I just have the stock power steering setup with a 4" dropped arm.
I just wonder why everybody states that you need a high steer (expensive) setup to run a SOA.
skizriz is online now
post #49 of 58 Old 09-18-2011, 07:56 PM
LibertyJeeper
Never heard anyone say you need a high steer. Most people do it because it is not not that expensive if you can barrow a reamer and it moves crap up higher away from obstructions.
post #50 of 58 Old 10-22-2011, 01:14 PM Thread Starter
gojeepin
1983 CJ7
Updated... today. Made some corrections and finally got the illustrations to look decent in PDF format.
Be patient, you'll download a PDF article... (updated 20 Oct 11)
I deleted the XPS version since I got the PDF version to look decent.
Steering and suspension basics
NOTE: If the the page appears black after the file loads, just scroll down for the image to appear.
gojeepin is offline
post #51 of 58 Old 10-23-2011, 08:33 AM
ahar9
mine works thanks
ahar9 is offline
post #52 of 58 Old 02-25-2012, 10:12 AM Thread Starter
gojeepin
1983 CJ7
Updated with new section on drive-line offsets to improve understanding of drive-line angles.
Be patient, you'll download a PDF article... (updated 25 Feb 12)
Steering-and-suspension-basics
gojeepin is offline
post #53 of 58 Old 02-25-2012, 10:32 AM
John87
wow, lots of info here! thanks!
-John
°llllll° 1985 CJ-7
John87 is offline
post #54 of 58 Old 02-28-2012, 10:01 AM
remmons
Very nice! Well done! I vote that this should be a sticky on all models.
Robert.
remmons is offline
post #55 of 58 Old 03-06-2012, 06:23 AM
diddy2003
Very nicely done. Thanks.
diddy2003 is offline
post #56 of 58 Old 06-30-2012, 11:33 AM Thread Starter
gojeepin
1983 CJ7
UPDATED 30 Jun 12: Added driveline phasing illustration and explanation.
To aid in explaining how driveshaft angles cause a phase shift twice per rotation, I continued the thought with a new illustration and discussion.
gojeepin is offline
post #57 of 58 Old 06-30-2012, 11:51 AM
nshefbuch
1982 CJ7
I think you may be mistaken. Moving the steering to the top of the tie rod hole is not high steer. When going soa yes you need high steer to have all the geometry in the correct place. Even on stock springs this is necessary. High steer means moving the steering bars above the leafs at the top of the knuckles. You can cut off the tie rod hole as it won't be used. This is a true high steer. What many do is keep the tie rod bar in stock location and add one high steer arm to the passenger knuckle and connect the drag link there. This will work also but of course the tie rod bar is susceptible to damage.
Why high steer? Any angle at all on the drag link allows for bump steer. To eliminate bump steer the drag link needs to be parallel. Steering stabilizer shocks only try to dampen it instead of fixing it. On crap setups you will see the drag link bent or "S" shaped to avoid hitting the leaf spring. This is the worst setup to do. I've seen these break pretty easy and would be scary on the road hitting a large pot hole.
Pic of high steer
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
post #58 of 58 Old 06-30-2012, 12:10 PM Thread Starter
gojeepin
1983 CJ7
Thanks for the input...
Let's try to keep this thread limited to questions about, omissions in, and clarification needed in the article.
Mike
gojeepin is offline
Atmospheric Pressure effect on Compression Testing Hybrid Jeep Jeep CJ Forum 4 03-11-2009 01:59 PM
Effect of vacuum leak PaulS Jeep CJ Forum 3 06-05-2008 09:56 AM
How does larger tires effect speedometer and odometer? Lupulin Jeep CJ Forum 5 05-28-2007 02:50 PM
effect of tires on speed T-$$ Jeep CJ Forum 2 08-24-2006 07:17 AM
