Edelbrock Performer cam - JeepForum.com
post #1 of 8 Old 04-30-2010, 06:49 AM Thread Starter
JohnnyRotten
1978 CJ5
I am considering installing an Edelbrock performer cam in my 360 I'm getting to drop into my CJ5. Is it worth the trouble to install it. How much "seat of the pants" difference is there over stock. I already have the Performer intake and a 600 Holley with headers. Also have the MSD 6a hooked up. Just wanting to get a couple of opinions on if it was worth it to you. Thanks
JohnnyRotten is offline
post #2 of 8 Old 04-30-2010, 06:51 AM
GP_Pete
GP_Pete's Avatar
THat's pretty much the setup I have.
I don't know if the cam alone is going to make a HUGE difference. It will make 'some'. That edelbrock stuff works really well when you use it all together as a system.
I would say go for it.
GP_Pete is offline
post #3 of 8 Old 04-30-2010, 12:21 PM
hold24
1977 CJ7
I have the performer rpm package on my 304 and it made a huge difference in seat of pant's feel. I think it was worth the cam and lifters. With a 360 I bet it's even more noticable.
1978 cj7 Black Renegade levis ....304 3spd hardtop ps pb tilt tac and clock ac...
1979 cj7 Cumberland green Golden Eagle 18k Original miles V8 auto..100% rust free Oregon Jeep..
hold24 is offline
post #4 of 8 Old 05-02-2010, 05:46 AM
marmaduke
marmaduke's Avatar
It's quite a simple upgrade, I replaced the timing gears and chain whilst I was at it
'86 cj7, 360 cui, msd ignition, hedman htc's and still upgrading
marmaduke is offline
post #5 of 8 Old 05-02-2010, 09:16 AM
timmayham
Slapped a Perfromer cam and intake on my 360 when I rebuilt it. The enigine is powerful and idles fine. A cam shaft is like the brain for you engine. A friend of mine who builds drag cars is religious about cam shaft upgrades. To answer your question, "is it worth it?" I'd say yes. There is more to it then just the cam though. Edlebrock says to use "Sure Seat" valve springs with the cam. I also used their performer timing chain and new push rods/rockers (factory replacement rockers and Comp Cams push rods). My cam came with new lifters. Another thing to keep in mind is cam break-in! I have read and been told that flat tappet cams can fail prematurely if they are not broken in properly. Eldlebrock said to run the motor at 2000-2500 RPM for the first 20 min upon initial start up. Also with flat tappet cam break-in you may want to consider buying a bottle of ZDDP addative, bought my ZDDP (by Lucas) at a local auto part/machine shop for about $9. I have seen it on Summit Racing's website also. I think Royal Purple sells a break-in engine oil now too that has ZDDP addative in it already. Good luck!
Proving daily that I have gears for brains!
timmayham is offline
post #6 of 8 Old 05-02-2010, 09:38 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
^Or you can just use the Rotella oil.
Pacfanweb is offline
post #7 of 8 Old 05-02-2010, 04:47 PM
Fatman
Fatman's Avatar
2008 CJ7
Was going to run the Performer RPM cam, was talked out of it.
went with a Comp Cams Xtreme energy 4x4 cam.
X2 absolutely !
Thread Links:
Fatman is offline
post #8 of 8 Old 05-02-2010, 05:27 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
I have an Xtreme 4x4 cam also. X4270H
Bowl Vent on Edelbrock Performer???? GP_Pete Jeep CJ Forum 7 04-02-2010 11:07 AM
Going to an Edelbrock Performer intake from a Torker Death_Eagle_571 Jeep CJ Forum 4 12-20-2009 12:06 PM
Need help adjusting an Edelbrock performer 650 on a 360 cracked91 Jeep CJ Forum 1 12-06-2009 01:41 PM
edelbrock performer package 304 hold24 Jeep CJ Forum 15 06-11-2009 11:34 AM
Edelbrock Performer RPM cam install questions webdr Jeep CJ Forum 1 03-30-2006 07:49 PM
