Edelbrock Intake on a 304 V8 - JeepForum.com
post #1 of 13 Old 08-31-2012, 02:50 PM Thread Starter
bigdee2
It's been about 8 months since I pulled the factory intake to replace it with an Edelbrock Intake. Please remind me of the following:
1. At the rear of the intake, close to fire wall behind the carb, there is a hole about 3/4" to 1" that is not threaded - what connects here, was it something for the emmissions/smog - if so, any recommendations on how to seal it off?
2. What hose and where does the other end of the hose go from the small hole of the water outlet on the front of the intake? Maybe the water pump or one side of the heater core at the fire wall?
bigdee2 is offline
post #2 of 13 Old 08-31-2012, 03:02 PM
CSP
The hole at the back of the intake is for the PCV valve. You want to use this.
CSP is online now
post #3 of 13 Old 08-31-2012, 03:23 PM
82JeepCJ7
1982 CJ7
That small hose coming off the thermostat housing is called the bypass hose. The hose you have to buy is molded and will fit perfectly. It attaches to the water pump.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #4 of 13 Old 08-31-2012, 03:55 PM
Dadamsnv
1977 CJ5
Listen to CSP, you want to use this
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #5 of 13 Old 07-11-2013, 07:40 AM
70worm
1977 CJ5
Can that gromet be bought from edelbrock
70worm is offline
post #6 of 13 Old 07-11-2013, 12:29 PM
82JeepCJ7
1982 CJ7
Mine came in the Fel Pro gasket kit I used..
post #7 of 13 Old 07-11-2013, 12:56 PM
13riverking
1981 CJ7
I used a ford small block grommet and pcv from nappa. Works great. The grommet was a tight fit.
13riverking is offline
post #8 of 13 Old 07-11-2013, 02:12 PM
fuzz401
1978 CJ7
http://www.autozone.com/autozone/par...mString=search
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #9 of 13 Old 07-17-2013, 11:58 PM
13riverking
1981 CJ7
Fuzz is this the grommet that fits the after market edlebrock intake or the original 2 barrel AMC intake?
post #10 of 13 Old 07-18-2013, 12:00 AM
13riverking
1981 CJ7
Nothing comes up on your link
post #11 of 13 Old 07-18-2013, 12:04 AM
fuzz401
1978 CJ7
same grommet should fit either intake
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #12 of 13 Old 07-18-2013, 12:22 AM
fuzz401
1978 CJ7
http://www.ebay.com/itm/AMC-Jeep-V8-...3b0e70&vxp=mtr
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #13 of 13 Old 07-18-2013, 08:50 AM
CSP
Just get a factory replacement at a local auto parts store, which will fit the Edelbrock manifold.
CSP is online now
Buick 231 edelbrock intake question...anyone familiar w/Edelbrock? robdoggydog1 Jeep CJ Forum 3 03-16-2011 05:57 PM
Edelbrock 4rb intake? kmm Jeep CJ Forum 2 11-22-2010 06:47 PM
PCV Valve with Edelbrock Intake sevenlitre2002 Jeep CJ Forum 4 01-24-2009 08:10 PM
Edelbrock Intake fluid_grind Jeep CJ Forum 3 02-24-2007 11:18 AM
