Edelbrock Fuel Line on 304 - JeepForum.com
post #1 of 7 Old 05-26-2009, 09:04 PM Thread Starter
chet44
When I bought my Jeep it came with a brand new Edelbrock carb. It also came with a overpowered electric fuel pump, and a rubber hose for the fuel line all the way from the tank to the engine. I didn't like the pump or hose so I replaced both with a mechanical pump and steel line. I saw the fuel line set up below at Edelbrock's web site and decided that it would be great to eliminate the hose running along the front and top of my engine.
I bought it a month ago and finally had time to install it this weekend. However, I hit a snag. It turns out that the end of the line with the elbow is a 3/8" pipe thread, and that is supposed to connect to the fuel pump. The stock mechanical fuel pump (At least the one I have), takes a 5/16" flared fuel line with the threaded nut. Just by coincidence, Edelbrock sells a mechanical fuel pump that has 3/8" pipe inlet and outlet. However, $135.00 seems a bit steep for a fuel pump. I have looked at several industrial supply stores for an adapter, but have not been able to find one. Anyone here have any ideas for this? Besides dropping $135.00 for a fuel pump. Any help would be appreciated.
chet44 is online now
post #2 of 7 Old 05-26-2009, 09:12 PM
John N
1981 CJ8
Call Summit. I'd bet they sell an adapter fitting.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #3 of 7 Old 05-27-2009, 12:14 PM Thread Starter
chet44
Thanks, John. I didn't think of them.
post #4 of 7 Old 05-27-2009, 12:46 PM
scottymac62
1979 CJ7
I know Summit will carry the fitting you need. I use the one in McDonough and their personnel are very good at finding these kind of things for you.
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #5 of 7 Old 05-27-2009, 04:10 PM
fuzz401
1978 CJ7
look at earls fittings for what you need
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #6 of 7 Old 05-27-2009, 06:45 PM
davemci
1978 CJ7
I don't see how this eliminates the line from running along the front and top of your engine? What am I missing?
davemci is offline
post #7 of 7 Old 05-27-2009, 08:04 PM Thread Starter
chet44
It's not a bare rubber hose. I also fabbed some brackets to hold it away from the engine. the PO had it sort of draped over the front of the engine.
Webber questions about fuel pressure regulator and fuel return line jatepper Jeep CJ Forum 26 01-19-2011 07:17 PM
fuel draining back out of fuel line ? OldSkull Jeep CJ Forum 10 08-27-2009 06:26 PM
brake line for fuel line USMCredneck Jeep CJ Forum 4 04-13-2008 10:37 PM
Dumb Brake Line and Fuel Line Question GroundUpCJ7 Jeep CJ Forum 3 04-02-2007 07:01 PM
84 cj7 fuel line bruisedfighter Jeep CJ Forum 1 11-27-2006 03:10 PM
