ECU removal question - JeepForum.com
post #1 of 9 Old 02-11-2013, 09:50 AM Thread Starter
crushedcan
1983 CJ7
This may be elementary but I am a rookie and I want to reassure myself. I have a rebuilt 258 with a weber 38. Also I installed a new centech wiring harness and a stock distributor, coil and motorcraft ignition box. I don't see any reason that I can't eliminate the ECU. Am I correct?
crushedcan is offline
post #2 of 9 Old 02-11-2013, 10:11 AM
vinnyabs
1983 CJ7
You are correct. Search for how to do a 'Nutter bypass'. It is a simple way to directly wire the ignition together without input from the evil box. The write ups are very thorough and you will soon be getting more into your engine compartment than you thought. The end result when tuned right will amaze you and make you proud
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline
post #3 of 9 Old 02-11-2013, 10:29 AM
MoC
When you installed the weber and new wiring harness did you wire the computer back in?
MoC is offline
post #4 of 9 Old 02-11-2013, 10:36 AM Thread Starter
crushedcan
1983 CJ7
No I have not wired it back in. The way I am seeing it, the ECU can be removed from the jeep.
post #5 of 9 Old 02-11-2013, 10:40 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
As Vinny said, removing the computer is a very common mod on later CJs. It's even got a name, the "Nutter Bypass".
A few searches will provide a butt-load of info on it.
Matt
Matt1981CJ7 is offline
post #6 of 9 Old 02-11-2013, 11:11 AM
248107
1983 CJ7
Look for a post by Luckycheesehead
248107 is offline
post #7 of 9 Old 02-11-2013, 11:33 AM
keith460
Jeep. There's Only One
keith460's Avatar
Yes, that's correct. Once the Weber is installed, no need for the ECU and all related wiring to it can be removed. It will really clean up the engine bay and not look so cluttered with all the extra wiring that is not needed.
After it is removed, you should have a pile that looks like what is pictured below.
1984 CJ-7 Renegade
keith460 is online now
post #8 of 9 Old 02-11-2013, 11:35 AM
frhrwa
Fish'n Fool
frhrwa's Avatar
you will also get rid of 10lbs of vacuum tubes and hookups.. really cleans it up.. don't forget to reset the timing immediately after the nutter bypass.. I think it was 8degrees..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #9 of 9 Old 02-11-2013, 12:15 PM
MoC
If you did not wire it back in and have replaced the harness then no need to do the nutter bypass, since that involves removing it from the orignal harness.
MoC is offline
