Easy question re 78 CJ 6 bolt hubs - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Easy question re 78 CJ 6 bolt hubs
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCCOR is your 1 stop source for everything Jeep!
Unread 02-26-2015, 04:17 PM   #1
OldGyrene
Semper Fi
1978 CJ5
So after putting new shocks, brakes, etc on my 78, I thought I would pull the locking hubs while it was on the stands. I checked my FSM and the net and couldn't find the answer (first time I ever pulled the lock outs off any jeep).
Below are a couple of pics after pulling the outer housing off the 6 bolt hubs.
As I pulled them off there was the outer housing, then an internal gear, then the spring.
On the passenger side (right side of the pic below) the gear and the spring slide right off over what looks like a retaining ring.
Driver side, the "gear" was held on by the retaining ring and the spring was compressed behind it.
So what was going to be an easy "let's clean, inspect and lube the hubs" turned into a WTF moment.
SO:
1. Should the "gear" slide off over the retaining ring ?
2. I'm thinking the springs should be of equal length.?
Is this fixable or am I looking at new locking hubs ?
Any pics of how it should be ?
Thanks in advance ! While I don't post a lot here I have read over 1400 pages in this forum and appreciates everyones expierence and input
EDIT: well, hell, photobucket isn't letting me link, but I'm guessing anyone who has done this knows what I am talking about.
Will try another photo service shortly.
Jake
OldGyrene is offline   Reply With Quote Quick reply to this message
Unread 02-26-2015, 08:27 PM   #2
only in a jeep cj
While this is a picture of 5 bolt lockout, the parts are the same. Items 9 to 15 show the parts and order from outside to in.
Yes, the springs should be the same length and the sliding rings are a unit on the end of the axle shaft held with a snap ring (not pictured)
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote Quick reply to this message
Unread 02-26-2015, 08:35 PM   #3
Spieg8
1984 CJ8
Pretty sure the gear and spring should not come off until the clip is removed. Sounds like you may have some worn/damaged parts (not sure if you can get new parts for those hubs anymore but I see used lockouts for sale from time to time). The springs should be the same length, but I don't think a little difference will matter matter much so long as they are strong enough to push the gear out.
Spieg8 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 07:16 AM   #4
OldGyrene
Semper Fi
1978 CJ5
Ed, thanks for the parts picture: I will save that to my files.
Spieg8: that's what I was thinking. Thanks for the info.
So, I am guessing that I can button it back up, minus the spring and sliding gear and drive it while I am waiting for new lock outs ? Can't see where it would hurt anything.
Any recommendations on suppliers ? Mile Marker ? Warn ?
I don't wheel her hard, just snow and mud.
Jake
Unread Yesterday, 08:00 PM   #5
Budowski
Budowski's Avatar
1978 CJ7
Hey OldGyrene
This is the only picture I have of mine from a few months ago when I rebuilt the dana 30. Hope this helps. It should have things in order - but I'm no pro and not sure what the PO may have done but this is how things came out. Also check this diagram out
http://ww2.justanswer.com/uploads/wo...6_012734_1.gif
'78 Rebuilt 4.2 258, T150, Spicer 20, Dana 30 front, AMC 20 rear
'80 CJ7 frame
Corrected: '84 CJ Tub
Budowski is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 08:03 PM   #6
Budowski
Budowski's Avatar
1978 CJ7
You know I re-read your post and mine was similar - different order on the last 3 pieces for the passenger and driver side. That 5 bolt lockout looks very different however. Im really trying to remember how I put it back together. PM if you have any problems and Ill try to get some more pictures or pull my hubs to check.
'80 CJ7 frame
Unread Today, 08:24 AM   #7
OldGyrene
Semper Fi
1978 CJ5
Thanks for the pic and the link. Yeah, I spent some time at the bench yesterday scratching my head over Ed's pic and my setup. The I realized his pic shows it torn down as far as it will go, thus the "extra" washers and circlips.
Ordered some Mile Markers yesterday. We'll see how they work out.
Jake
