Easy question from a newbie - JeepForum.com
post #1 of 8 Old 04-27-2013, 11:08 AM Thread Starter
bears84CJ7
I have an 84 CJ7 with lots of years of good service, with minimal maintenance and repairs. I have just started a basic refurbishing, then will get into rebuild making it nice. Tackling mechanical first, and since I don't know much I found you guys.
Anyway - radiator was leaking, and can't have that here in Phoenix - summer is here. Got new 3-row radiator and put it in. I cut down the spacer between the water pump and fan to allow room there, but now the fan shroud does not fit properly. I could modify it a little, but is it really necessary? Can I live without it or will I regret not having it on there??
What do you think?
bears84CJ7 is offline
post #2 of 8 Old 04-27-2013, 11:15 AM
RamblingCJ
What spacer did you cut down? Not sure what you are meaning. I hope you're not meaning the harmonic balancer......
As far as the shroud, it is not necessarily needed for it to run properly, but it definitely will help keep fingers and rocks from getting in there easily. You might see a little more heat than running with it, but I think you'd be fine.
RamblingCJ is offline
post #3 of 8 Old 04-27-2013, 11:17 AM
RamblingCJ
Oh, and Go Bears!
post #4 of 8 Old 04-27-2013, 11:22 AM Thread Starter
bears84CJ7
I had purchased an after-market fan several years back when the fan clutch went out. It came with a 2.5" aluminum spacer to position the fan properly between the engine and radiator. Since the new radiator is thicker (and mounts a little further back) the fan was only a half inch or so from it. I had a machine shop cut the aluminum spacer down to about 1.5" to allow a little more room. I don't know what the harmonic balancer is, but I will make sure. Any other thoughts?
post #5 of 8 Old 04-27-2013, 11:26 AM Thread Starter
bears84CJ7
Definately not the harmonic balancer. Just an aluminum spacer. Does anyone think I will have a big difference in cooling ability if I leave the fan shroud out?
post #6 of 8 Old 04-27-2013, 11:28 AM
RamblingCJ
Personally, I'd try and get it on there. Mine has been cracked and a piece removed forever and it's on my to-do list when I put in a new pump and thermostat.
post #7 of 8 Old 04-27-2013, 11:30 AM
Jester77
You shouldn't see a big difference in the overheating/cooling aspect. At least I wouldn't think. But if you decide you are not going to use it and want to sell it, I'm your man.
jester
Air Force Jeep Club - Tail # 200
"You miss 100% of the shots you don't take." Wayne Gretzky
Jester77 is offline
post #8 of 8 Old 04-27-2013, 11:32 AM
RamblingCJ
jester
X2 on the overheating/cooling.
