easiest/ cheapest transmsiions swap - JeepForum.com
post #1 of 13 Old 07-08-2011, 11:03 PM Thread Starter
CallMe_Lockouts
so i have a 1980 cj7 4.2L |6 and the dreaded SR4 went out in it. i am trying to get a used transmission from a self service junkyard but i need to know what transmissions have similar bolt patterns to the SR4. also i wan to know if it would be easier to keep my bell housing and get a new transmission or if i should get the bell housing with the tranny i buy. right now i just wanna drop the tranny and put the new one on w/o an adaptor kit b/c money is very tight. any advice will help
CallMe_Lockouts is offline
post #2 of 13 Old 07-09-2011, 12:36 AM
zeronight
1982 CJ7
zeronight is offline
post #3 of 13 Old 07-09-2011, 12:49 AM
only in a jeep cj
Only swaps I know of involving the transmission only and no other parts swapping would be another SR4, a T4, and the T5. I have all three and prefer the T 5 only when used with the correct tire size and axle gearing.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #4 of 13 Old 07-09-2011, 04:19 AM Thread Starter
CallMe_Lockouts
so by the looks of it i'm gonna keep an eye open for a SM465 if i can find one. opinions?
post #5 of 13 Old 07-09-2011, 05:17 AM
Mister 4x4
1980 CJ5
If money is tight then any swap to a different tranny is not a good idea. Drive shaft adjustments, adapters to motor and to the transfer case, clutch, shifter boot, all add up and can easily approach the 2 grand mark. Your transmission last over twenty years so i did ok. On a budget, replace it with another sr4.
Mister 4x4 is offline
post #6 of 13 Old 07-09-2011, 05:43 AM
nshefbuch
1982 CJ7
Not sure if high speeds matter but the sm465 will mainly act as a 3 speed and give you the same final gear. Also these can be expensive in themselves. But it and it's sister tranny are very strong. Keep in mind the transfer case too. That can get expensive with an adapter. It's a short tranny and the modification needed to your existing shafts might not be that bad on price.
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
post #7 of 13 Old 07-11-2011, 08:38 AM Thread Starter
CallMe_Lockouts
i went to a junkyard that was having a special and carried a T4 tranny & Tcase for 20 feet for a flat rate of $40. what are the ups and downs of a T4?
post #8 of 13 Old 07-11-2011, 08:48 AM
MoC
T4 Info here.
What did it come out of?
MoC is offline
post #9 of 13 Old 07-11-2011, 08:58 AM Thread Starter
CallMe_Lockouts
it looked like another cj7 but i couldnt tell. literally the only thing left was the engine and tranny and bumpers. radiator windshield and interior was gone. it was just a shell left with axels
post #10 of 13 Old 07-11-2011, 10:52 AM
only in a jeep cj
Was it wrecked? I'm always leary of vehicles in the salvage yards with no signs of being wrecked. It's great for sheet metal parts and stuff that doesn't really wear out. But for the drivetrain, It tells me either it was in a flood and there might be water in the engine / transmission / t case, OR one of those items is bad and cost too much to replace it than what the vehicle was worth so the owner scraped it. So it's kind of a gamble.
The t4 is a slightly better version of the SR4 with the standard shift pattern with reverse in the more common location. To me, they feel a bit tighter too.
Ed
1975 CJ-6 1983 CJ-8
post #11 of 13 Old 07-11-2011, 02:35 PM
davbytrace
1979 CJ7
I have a complete T150 transmission and Dana 20 T-case, with bell housing, clutch and pressure plate. I pulled it out of a 1975 CJ. Will fit perfectly. PM me if you want it.
Dave
davbytrace is offline
post #12 of 13 Old 07-14-2011, 10:35 PM Thread Starter
CallMe_Lockouts
well i got down and dirty and now i think its actually a T18 because the shifter is directly ontop of the gear box and uses a fork design to shift it. but the input shaft is not the right size so i'm back where i started
post #13 of 13 Old 07-14-2011, 11:28 PM
BagusJeep
1981 CJ7
The t18 came in all manner of input shaft sizes, what is the challenge with the one you have?
BagusJeep is offline
cheap , cj7 , swap , transmission , transmission bolts
Cheapest/Easiest Way to get a little lift?? shelbyle Jeep CJ Forum 18 10-16-2010 07:41 AM
Easiest Rear-End Swap for a CJ-7? cfljeep Jeep CJ Forum 11 03-13-2008 05:46 AM
Easiest engine swap dblock16 Jeep CJ Forum 4 02-03-2007 03:05 PM
Best & Easiest Axle Swap for CJ 77deluxe Jeep CJ Forum 7 12-03-2005 08:34 AM
Easiest Tranny/Motor Swap ? icarus00000 Jeep CJ Forum 14 12-30-2002 07:38 AM
