early cj5 steering box removal - JeepForum.com
post #1 of 6 Old 07-27-2010, 03:42 PM Thread Starter
gooseofdeuce
i'm having a problem removing the steering box on a 65 cj5. any tips, tricks, or help would be appreciated. I have a manuel but it only covers later models than mine.
gooseofdeuce is offline
post #2 of 6 Old 07-27-2010, 07:21 PM
Rattyflatty
1948 CJ2A
Remove draglink that goes to the bellcrank
Remove steering wheel and turn signal assembly
Unbolt column from dash and floor
Unbolt steering box from frame and slide it down
Also the horn wire on the box if it is still there
Happy wrenching
Rattyflatty is offline
post #3 of 6 Old 08-16-2013, 06:42 PM
DourRyland
1969 CJ5
Do you know if process will be the same on 1969 cj5 with V6 engine?
DourRyland is offline
post #4 of 6 Old 08-17-2013, 07:34 AM
colojeepguy
1970 CJ5
Yes. All CJ's 71 & older use a Ross steering box which is integral with the steering column. This is assuming that it's stock. Lots of early Jeeps have steering conversions...
"It's better to have loved and lost, than to live with a psycho the rest of your life"
colojeepguy is offline
post #5 of 6 Old 08-17-2013, 08:25 AM
DanStew
1963 M-38
Soak the steering wheel splines with penetrating oil. That is the hardest part of the hole disassembly, getting the steering wheel off.
Dan Stewart
1991 Wrangler
DanStew is offline
post #6 of 6 Old 08-21-2013, 10:52 AM
DourRyland
1969 CJ5
Got it out and to Precision Drive Line in Phoenix. They had it rebuilt in a couple of days. Will let you know how it works after I get it back in and drive it some.
Steering shaft from early CJ fit a 79 CJ7 OlivergreenCJ7 Jeep CJ Forum 2 07-24-2009 05:31 PM
Early CJ FRONT Drum Removal - Help! Docaggie07 Jeep CJ Forum 8 07-12-2009 09:15 PM
early Jeepster hood on a early CJ? T Hoff Jeep CJ Forum 12 10-22-2008 04:56 AM
Steering box removal CJhollic Jeep CJ Forum 4 07-21-2008 10:08 PM
Steering part for an early cj5..... famicom21 Jeep CJ Forum 2 08-01-2006 06:20 PM
