Early CJ Horn Button Removal, how? - JeepForum.com
post #1 of 7 Old 08-19-2013, 07:32 PM Thread Starter
W_A_Watson_II
OK, I've searched and can't seem to find any reference for the proper way to remove the horn button on the old style CJ steering. I thought it would pop out with a little perspiration, but I'm afraid too try too hard.
The spring is a little too weak, and I need to replace/adjust the spring so the horn doesn't hook too easy, or on it's own.
Will Watson
1993 Jeep YJ 4.6L Stroker (jeep.wawii.com)
1946 & 49 Dodge Power Wagon, 1953 Dodge M37
W_A_Watson_II is offline
post #2 of 7 Old 08-19-2013, 07:58 PM
OleBlue73
1973 CJ5
It will pop out with a screw driver and perspiration. Take a small screw driver and work it around the edge of the button carefully. Give the screw driver small twists.
1973 CJ5, 304, T15, D20
2009 JKU, Rubicon
2005 TJ, X, 4.0, 6 speed
OleBlue73 is online now
post #3 of 7 Old 08-19-2013, 09:30 PM
bradleybrb
1975 CJ5
Yep, that's the way. As said, be careful or you will chip the steering column around the button.
bradleybrb is offline
post #4 of 7 Old 08-19-2013, 09:32 PM
bradleybrb
1975 CJ5
Now that I think about it, I don't remember mine having a spring under the button though. Maybe the copper piece is broke or lost it's "flex".
post #5 of 7 Old 08-19-2013, 10:13 PM Thread Starter
W_A_Watson_II
Thanks, I'll try it again, with care.
Will Watson
post #6 of 7 Old 08-21-2013, 07:32 AM Thread Starter
W_A_Watson_II
Well, no luck. Wonder if the previous owner glued the button in place?
Will Watson
post #7 of 7 Old 08-21-2013, 08:24 AM
Neuner-9R
Could be. My PO screwed mine together with a drywall screw.
Neuner-9R is offline
