E3 Spark Plugs ? - JeepForum.com
post #1 of 16 Old 09-07-2013, 03:58 PM Thread Starter
DoubleDown
1983 CJ7
E3 Spark Plugs ?
Has anyone tried these ?
http://www.e3sparkplugs.com
I have an '83 CJ7 4.2L, Nuttered and Team Rush upgrade and was wondering if these plugs would help or hurt combustion chamber temperatures ?
DoubleDown is offline
post #2 of 16 Old 09-07-2013, 04:04 PM
jeepwhore
Save your money. Go with the tried and true Autolite or Champion plugs. Those fancy schmancy plugs seem to do nothing but make old CJ's run like ****.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 16 Old 09-07-2013, 04:07 PM Thread Starter
DoubleDown
1983 CJ7
What "gap" should my champion plugs be set ? I looked again through the Team Rush post, but could not find anything. They are just factory set right now, but Jeep runs hot and I think that's why.
post #4 of 16 Old 09-07-2013, 04:13 PM
LumpyGrits
Save the $$$, those are 'snake oil'.
Gap .045", and see how she runs.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #5 of 16 Old 09-07-2013, 04:41 PM
jeepwhore
What do you mean, "runs hot"? As in coolant temp. wise? I've never heard plug gap affect operating temp. I'd say you have other issues.
post #6 of 16 Old 09-07-2013, 04:43 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
The plugs spark will be too hot thus detonating the fuel before the piston can fully compress and you create a ping/knock
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #7 of 16 Old 09-07-2013, 04:44 PM
vinnyabs
1983 CJ7
X2 ddd1d. I put platinum plugs in and they burn too hot. Went back to my copper champions and a perfect color and smooth run. Just rebuilt the engine so I'm not risking a hole in a piston. You already made the upgrade with the nutter team rush combo. Only other thin you could do is msd ignition box instead of weak oem. Some will argue for HEI, but that has been exhausted an comes down to proper tuning and personal choice. Add the msd, put in a '81 mechanical dizzy and get your curve plotted right and that will be as perfect as you can ever wish for
The x2 was for LG's comment. My long winded ness let others sneak in between
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline
post #8 of 16 Old 09-07-2013, 04:45 PM
LumpyGrits
If it's run'n "hot", you got other issues going on. Like either to lean a fuel mix(vacuum leak)or cooling system issues.
I run a 195* t'stat year round, and mine never gets over 210*.
LG
post #9 of 16 Old 09-07-2013, 04:47 PM
WindKnot
1977 CJ7
Anything but good old copper plugs in our old Jeeps are a waste.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #10 of 16 Old 09-07-2013, 04:48 PM
LumpyGrits
Really, been run'm A/L 'plats' for 15 yrs or more. Never have had any issue. When I 'read' the plugs, they are a text-book tan color.
X2 on MSD!
LG
post #11 of 16 Old 09-07-2013, 05:29 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
I don't care what plugs you put in it, they aren't going to make the engine run hot.
Copper are the best for a Jeep.
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
post #12 of 16 Old 09-09-2013, 09:25 AM
wm69
Autolite 985 copper plugs. That's what AMC put in your 258. Gap it to .045 and go.
E3 are garbage. Can't believe they still make them.
wm69 is offline
post #13 of 16 Old 09-09-2013, 09:32 AM
LumpyGrits
NOPE, my '85, 4.2L came with and still uses Champion RFN14LY.
LG
post #14 of 16 Old 09-09-2013, 10:01 AM
waterdowg
LG
Yep all my Jeeps have come with Champions. Nothing has worked better.
waterdowg is offline
post #15 of 16 Old 09-09-2013, 02:32 PM
Drugcoder
LG
When I search parts stores online they are saying the RFN14LY will not fit my '79 258. They suggest using the RN13LYC instead. Are they right?
Drugcoder is offline
