****e.... cut a fuel line - JeepForum.com
post #1 of 15 Old 07-30-2007, 02:58 PM Thread Starter
TetanusCJ7
TetanusCJ7's Avatar
1978 CJ7
Cut a fuel line while trying to wrestle the rusted corpse of my tub from the frame. Nice straight cut......now what? Do I have to replace the whole thing or can I patch it with rubber tubing and clamps????
TetanusCJ7 is offline
post #2 of 15 Old 07-30-2007, 03:00 PM Thread Starter
TetanusCJ7
TetanusCJ7's Avatar
1978 CJ7
Oh, by the way...it was right under the driver's floor board toward the stick shift.
post #3 of 15 Old 07-30-2007, 03:16 PM
Jeepcreep927
I ran my Jeep when I first got it with about 5 pieces of rubber line spliced in 'cause I couldn't afford to replace them. It may not be the "right" thing to do, but I never had a problem. Just make sure you get all the metal particals out before you reconnect the line, and maybe run it for a bit when you get that far and replace the fuel filter. Good luck.
Jeepcreep927 is offline
post #4 of 15 Old 07-30-2007, 03:26 PM
350ci
Go to AutoZone (or whatever your local auto store is) and buy a few feet of rubber gas line. I just got 6 feet for about $2.50 or $5.00 I believe it was. Very cheap. If you decide to patch it with a rubber gas line, put a good 4" overlap on each side of the line to insure you wont have any leakes or worry about the line slipping off.
Obviously the best thing to do is replace it but if you dont have the dough, patch it.
CJ7 - Chevy 350ci, TH350, NP203 case, AMC20's, 36" RVT's.
350ci is offline
post #5 of 15 Old 07-30-2007, 03:37 PM Thread Starter
TetanusCJ7
TetanusCJ7's Avatar
1978 CJ7
did you guys use clamps to secure it or was the length on each side enough to keep it on?
post #6 of 15 Old 07-30-2007, 03:39 PM
4.7stroker
Use clamps it will be fine, just inspect the hose once a year.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #7 of 15 Old 07-30-2007, 03:41 PM
1979CJ7
1979CJ7's Avatar
1979 CJ7
i replaced all of mine with rubber hose from autozone. its like 1.25 a foot i think or less
i used regular hose clamps to secure it as well
1979CJ7 is offline
post #8 of 15 Old 07-30-2007, 03:45 PM
benjy
wow, 90psi with hose clamps... don't think I'd do it
benjy is offline
post #9 of 15 Old 07-30-2007, 03:46 PM
slacker92104
slacker92104's Avatar
If it's steel line, you could use a compression fitting. You can grab one from an autoparts store and it will be a much better fix. Pretty much permanent. It is definately a better fix. Just try to figure out the right size (but you would have to do that for the rubber hose and clamps). Should run you under $3.
Edit: They are good well over 100# of pressure, so they work fine on fue injected motors as well.
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
post #10 of 15 Old 07-30-2007, 04:17 PM
hfjeff
hfjeff's Avatar
deleted....
MINE: 1995 YJ/2.5L/115K/Completely Stock
MY DAD's: 1978 CJ7/ AMC 360 .030" over/ Motorcraft 2100/ Edelbrock Performer/ Proform HEI Ignition/ Hedman Headers with dual Flowmaster 40's/ Taurus Fan/ FK-35 Control/ Painless Harness/ Rebuilt T150 & Dana 20/ 4" Lift/ 31" Procomp Mud Terrains/ All Fiberglass. (SOLD)
MY BROTHER's: 1996 ZJ Limited/5.2L/117K & Completely Stock.(SOLD)
hfjeff is offline
post #11 of 15 Old 07-30-2007, 05:03 PM
79cj7reny
1979 CJ7
Just make sure you use rubber fuel line, not just vacuum hose.
79cj7reny is offline
post #12 of 15 Old 07-30-2007, 05:09 PM
Bard
Rubber will rot in the short run. Sounds like you cut the return line. I would replace them all since you have the body off, brake lines included. Much easier to do it now and the cost of the rolls are very inexpensive. Don't cut corners here.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #13 of 15 Old 07-30-2007, 05:15 PM
Rollbar
1984 CJ8
Yeah, I would to. I bought mine from www.inlinetube.com & they R stainless. I wouldn't skimp on safety, especally a fuel line. It's metal for a reason.
<----Click
<---- Click
Rollbar is offline
post #14 of 15 Old 07-30-2007, 07:41 PM Thread Starter
TetanusCJ7
TetanusCJ7's Avatar
1978 CJ7
That is what I get for trying to rush through this thing. Once I get the tub all the way off and inspect the rest of the lines the decision on what I should do may already be delt for me.
post #15 of 15 Old 07-30-2007, 11:42 PM
papaimp
My vote is for replacing them with new stainless lines, since you have the tub removed, anyway.
There is a metal option, if your local auto parts store carries them. There's brake line splices, used to join brake lines together, that may work for fuel lines. I can't recommend them in good faith, though.
papaimp is offline
Webber questions about fuel pressure regulator and fuel return line jatepper Jeep CJ Forum 26 01-19-2011 06:17 PM
fuel draining back out of fuel line ? OldSkull Jeep CJ Forum 10 08-27-2009 05:26 PM
brake line for fuel line USMCredneck Jeep CJ Forum 4 04-13-2008 09:37 PM
Dumb Brake Line and Fuel Line Question GroundUpCJ7 Jeep CJ Forum 3 04-02-2007 06:01 PM
84 cj7 fuel line bruisedfighter Jeep CJ Forum 1 11-27-2006 02:10 PM
