E-Brake hookup on Disc brakes - JeepForum.com
post #1 of 6 Old 03-05-2008, 06:02 AM Thread Starter
NWA_CJ7
1983 CJ7
Recently got a D-44 rear for the jeep and it has disc brake conversion the levers for the e-brake are on the calipers. How do I hook these up to the current e-brake setup (stock) do I need to purchase anything special to do it?
NWA_CJ7 is offline
post #2 of 6 Old 03-05-2008, 11:51 AM
ShovelheadDan
Man, there is no way that's gonna work. Send it to me and I'll get rid of it for ya.
ShovelheadDan is offline
post #3 of 6 Old 03-05-2008, 03:22 PM
jimsCJ5
1978 CJ5
What kind of calipers were used? Pictures?
jimsCJ5 is offline
post #4 of 6 Old 03-08-2008, 10:22 PM
JeepnBlake
actually you could probably hook up something fancy where the E-Brake had its own Master cylinder on it, but then it wouldn't tie into the existing setup very well I.E. you would only have front brakes from the pedal and back brakes from the E-Brake pedal....
doesn't sound fun to me... my $0.02 worth would be just put some wedges behind and in front of the wheels...
This would be a possible mod, but it would be very time consuming....
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #5 of 6 Old 03-09-2008, 07:12 AM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
if there any thing like the tsm conversion disks on my amc 20 the an Eldorado caliper..There should be a little lever on the rearwar side I beleive..The stock cables seemed to work but needed a bracket for the part of the cable that is pronged that used to slide into the backing plate..Ill take a pic today if ya need to..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #6 of 6 Old 03-10-2008, 06:47 PM
ovrlnd
if the calipers are the 80's caddy seville flavor like mine, I got a universal kit from lokar that worked great with only minor fab work on the factory YJ bracket to run the cables. I also recommend setting up the calipers with the rear inboard pad removed. I tried ratcheting the e brake lever with the inboard pad in place and the new pad would not allow enough movement to click to the next position on the lincoln rotors. where did you get the kit from?
another note I should mention is the seville calipers drained my rear resivoir on the m/c so I had to swap it out
"We'll get out of this disaster in time for the next one"
"I'm done recomboobulating the energy-mo-tron"
88 YJ, 350/350 Chevy, Twin Stick Dana 300 with JB 32 spline rear output, 6.5" lift, Front Scout II Dana 44 w/Yukon 4340 shafts, trac loc, 4.27's, Warn Premium Hubs, flipped YJ Tie Rod, Ford F150 front calipers, Rear Scout II Dana 44 w/Alloy 4340 shafts, HD RPT retainer plates, 4.27's True trac, Steeltech Disc brakes, Cage upgrade, B&M Prostick Shifter, Custom Fabbed tire, gas, jack carrier, 3/8 angle rear bumper, clevis's all around, old & reliable rep8000 winch. Flood lights. loud stereo. 35x12.50 swampers and a bunch of other stuff
ovrlnd is offline
rear disc brake conversion? brakes not brakey enough meatloaf Jeep CJ Forum 8 04-17-2008 09:39 AM
83 CJ7 with Disc Brakes lopezzi Jeep CJ Forum 2 11-18-2007 11:26 PM
73 with 78 disc. brakes??? fl-jeep Jeep CJ Forum 8 10-25-2007 06:51 PM
Disc Brakes? FILDO Jeep CJ Forum 9 07-14-2007 02:06 PM
power brake vacumm hookup question molsenice Jeep CJ Forum 8 03-09-2007 07:39 PM
