E-brake dash light comes on when brake is off...? - JeepForum.com
post #1 of 12 Old 06-05-2013, 07:51 AM Thread Starter
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'm hoping one of the electrical gurus can help me diagnose a recent problem.
My e-brake warning light has started randomly glowing when the e-brake is off. It doesn't illuminate full strength, however. When I set the e-brake the light gets brighter. When I release the brake, sometimes the light turns off like it should, other times it just dims to a faint glow.
I'm an electrical retard, so any advice is welcomed.
Thanks in advance.
Matt
Matt1981CJ7 is offline
post #2 of 12 Old 06-05-2013, 08:13 AM
lordhelemt
Check the plunger at the bottom of the e brake pedal and make sure its not sticking.
lordhelemt is offline
post #3 of 12 Old 06-05-2013, 08:20 AM
keith460
Jeep. There's Only One
keith460's Avatar
That's what I would suspect too.
1984 CJ-7 Renegade
keith460 is offline
post #4 of 12 Old 06-05-2013, 08:32 AM Thread Starter
Matt1981CJ7
1981 CJ7
Thanks, gentlemen.
Will do, and report back.
Matt
post #5 of 12 Old 06-05-2013, 09:29 AM
texasdave
texasdave's Avatar
1980 CJ7
You may have to adjust plunger distance from the pedal.
texasdave is offline
post #6 of 12 Old 06-05-2013, 10:49 AM
82JeepCJ7
1982 CJ7
Since my E-brake does not work, I simply unplugged the wire at the switch.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #7 of 12 Old 06-05-2013, 11:01 AM
pman
Matt- I've had the same issue on my Wagoneer for quite some time. Oddly, in my case it appears to be related to the drum shoe adjustment on the rear (I just haven't gotten around to pulling the drums/shoes and readjusting it) and/or the proportioning valve. Occassionally I'll slam on brakes, then feel a little "pop" and the light will go off, but only temporarily.
Can't wait to hear what you find out with yours. I'll certainly update what mine is when I get the chance to tear into it.
Edit: I'm at work so I didn't read your symptoms as carefully as I should have the first time. Mine is only a "slightly" fainter glow, and is less erratic, so yours certainly does sound more like an electrical issue.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #8 of 12 Old 06-05-2013, 11:14 AM
John Strenk
John Strenk's Avatar
1976 CJ5
The chang in brightness is interesting. If it was the ebrake or the combination valve as in pmans case it should glow brightly
But a glowing or a dim light sounds more like a pinched wire or something. The light has power going to it all the time, when one of the switches makes contact with ground it glows brightly.
It also goes to the ignition switch so that it turns on when starting the jeep. or it should.
When a bulb is dim it's usually a sign of something in series with the bulb splitting the voltage between the bulb and something else. Usually another bulb will have the right reesistance to split the voltage evenly to dim the bulb.
So what does that leave us with?
A poor ground in the harness.
Somewhat conductive grease/dirt in the switches.
A poor short to ground. (The worst type.)
I would disconnect the e-brake connection and see if the problem goes away. Then reconnect it and see if it comes back. If it does, clean the switch with tuner leaner.
If it still doing it, I would check to see if the wires going to the Combination valve is melted against the exhaust pipe. Great place for a poor ground.
John Strenk is offline
post #9 of 12 Old 06-05-2013, 12:43 PM Thread Starter
Matt1981CJ7
1981 CJ7
Well, I did my normal, highly scientific, electrical diagnosis (basically I jiggled a bunch of wires), and the problem has gone away, at least for now.
Yeah, sorry, I know that's not a very useful solution...but it works for me, at the moment.
If the problem re-appears, and I find a more specific cause and solution, I will dredge this thread back up.
Thanks for all the helpful and timely replies.
Matt
post #10 of 12 Old 06-05-2013, 08:47 PM
james04si
james04si's Avatar
1977 CJ5
Its funny you saying jiggling the wires is not a technical way to resolve an issue. My 2004 Honda FSM says to do that for issues with the SRS light and only trace possible wiring problems if it occurs more than 2 times. Had mine in 2x under warranty and wouldn't you know it came on less than 1k miles after the warranty expired again. Ohh well I've driven it 70k more miles now and don't even notice the light anymore.
james04si is offline
post #11 of 12 Old 06-05-2013, 09:32 PM
Matt80cj
1980 CJ7
i had an e brake light issue with mine but it stayed on bright when the brake was off. The plunger was bent and would rotate every once in a while and miss the brake lever. I think I finally got it straightened out enough to where it won't miss the brake lever again.
Matt80cj is offline
post #12 of 12 Old 06-05-2013, 09:35 PM
fourbtgait
1930 MK Patriot
Matt
Mine would not come on when supposed to.
I also scientifically jiggled them and in a certain position it works.
So i duct taped it to the tub in that position......
Russell
fourbtgait is offline
