Durango steering gear question. - JeepForum.com
post #1 of 10 Old 11-10-2011, 06:14 PM Thread Starter
skizriz
1978 CJ7
Before I pull the trigger on a box from a 88 4x4 V8 durango, 30k miles on it, I am also going to order a Rugged Ridge HD bracket and brace combo to mount it up since I have it off.
My bell coupling also leaves a lot to be desired, torn boot and all.
Do I also order a replacement JEEP bell coupler with it?
Anybody see any problems using the box with the HD bracket and brace?
Are the splines for the pitman arm the same? I have a 4" dropped.
All of the information I could find was for newer Jeeps. Just wanted to get as much info as I can before I start tearing my steering apart.
skizriz is online now
post #2 of 10 Old 11-10-2011, 06:26 PM
waterdowg
I have done alot of research on this as I plan to do the same if my box turns out to be bad. I assume you mean 98 durango not 88.
The splines for the pitman arm are the same. The input shaft for the steering shaft on the Durango box should 3/4" - 36 spline. So you would need to buy a coupler from a manual steering CJ. But someone on here got a Durango box that only had 30 spline. So before you order your new shaft and coupler get the box first to be sure of your spline count.
As for the HD bracket I don't see why it should not fit. The only thing is the Durango Box has 3 bolt were the CJ has 4 bolts on the steering box.
Edit: I just noticed you have a 79 CJ7. If you have power steering from that year you will need to get hose made. The Durango Box has o-rings on hose fittings, and the 79 had flange fittings. Or you could get a Power Steering box from a 82 or newer.
waterdowg is offline
post #3 of 10 Old 11-10-2011, 06:36 PM
nsargeant
1974 CJ5
I just did this swap on my 74cj5 and will give you as much info as i can. I do think that the splines on the pitman arm are the same. The splines were the same as a 74 cj with power steering. The biggest problem i think you might run into is that the splines on the steering box shaft of the durango box is 3/4" - 30 spline. You aren't going to find a bell coupler that will fit that.(at least I don't think so). There are a lot of post on here and other sites that say that a manual steering bell coupler will fit over it. That may be so in some cases, but mine it wasn't. It was a 3/4"- 36 spline. To alleviate that I bought a borgenson steering shaft with the right u-joint on each end and that fixed my problem.
nathan
nsargeant is offline
post #4 of 10 Old 11-10-2011, 06:40 PM Thread Starter
skizriz
1978 CJ7
My head has been so jumbled up with numbers lately. 98.
The Jeeps a 78, but I swapped to power steering 11 years ago and have no idea what year the box came off of. I put it on when I tore it down, and it had been sitting ever since.
I've been logging a lot of miles since getting it back on the road this summer, and a steering gear overhaul will be my winter project.
I guess I'll wait to get the box before ordering a coupler. I still have my manual box in the garage, so I'll compare splines to see which one I need.
I'll also have to wait and see on the hoses. I have a local company that custom makes hydraulic hoses, so getting whatever I need made shouldn't be a problem.
I hope my stock pump can handle the box ok.
post #5 of 10 Old 11-10-2011, 06:44 PM Thread Starter
skizriz
1978 CJ7
Thanks Nathan.
I haven't ruled out a new shaft also. Might as well do it from top to bottom. Just have to wait until I see how the funds hold up after Christmas for that.
But with no top, and winter coming, I have plenty of time.
Do you think it is worth the hassle?? Or take the easy route and drop on another Jeep box? Mine is sloppy and leaks like a sieve.
I was going with the Durango box because it has low miles, and it's $75.
I also hear they make a noticable difference in road manners.
post #6 of 10 Old 11-10-2011, 06:50 PM
waterdowg
Like Nathan said he got a box with 30 spline, others claim to have gotten bows with 36 spline so some were there is a difference in box production.
As for the hoses, when you remove yours from the box you will see if it has o-rings or flanges. The Stock pump should be fine.
post #7 of 10 Old 11-10-2011, 06:52 PM
nsargeant
1974 CJ5
skizriz,
i think the pump i had came out of a 87 wrangler and it doesn't seem like it has any problems. I will say that the borgenson steering shaft is really nice as were the people i talked to when I ordered it.
nathan
post #8 of 10 Old 11-10-2011, 06:58 PM Thread Starter
skizriz
1978 CJ7
Thanks guys.
Hopefully I'll be able to report back in the spring as to how it turned out.
Now to start collecting parts. One of my favorite hobbies.
post #9 of 10 Old 11-10-2011, 07:00 PM
waterdowg
Once you get your durango box post how many spline it is. I'm interested....
post #10 of 10 Old 11-10-2011, 07:02 PM Thread Starter
skizriz
1978 CJ7
I may pick up the box this weekend. I'll post it up if I do.
Durango Steering Box Upgrade on CJ? ibjeepin99 Jeep CJ Forum 19 11-15-2011 08:28 PM
steering gear box question like79 Jeep CJ Forum 2 08-21-2011 01:46 AM
durango steering box in cj5? HighFive Jeep CJ Forum 1 04-27-2011 04:51 PM
Power Steering Gear Box Question cobbcj7 Jeep CJ Forum 15 04-26-2009 07:18 PM
Steering Box Question-Durango Box Compatibility drummond Jeep CJ Forum 3 04-12-2009 02:43 PM
