Dumb driveshaft question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Dumb driveshaft question
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete Steering and more from Ruffstuff!Ruffstuff Axle Simple Swap Kit!
Unread 03-27-2014, 08:27 PM   #1
cdt540
1983 CJ7
I am in the process of putting everything back together after an engine rebuild and have a dumb question. I took a lot of pics of the engine, engine bay, wiring, etc. but did not take a pic of the drive shafts now I don't which ends face which. So for the front and rear shafts the end with the grease nipple goes towards the transfer case or the diffs?
Thanks
Chris
'83 CJ7 (258 4spd)
Austin TX
cdt540 is offline   Reply With Quote Quick reply to this message
Unread 03-27-2014, 08:29 PM   #2
RenoF250
The end with the sliding yoke goes towards the transfer case.
RenoF250 is offline   Reply With Quote Quick reply to this message
Unread 03-27-2014, 08:29 PM   #3
LumpyGrits
IF-You are talk'n about the slip spline.
I run at the T'case, to keep from beat'em on rocks.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote Quick reply to this message
Unread 03-28-2014, 05:44 AM   #4
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Mine are at the diff's. Might be pretty hard to grease if the front one it at the t-case above the skid plate or not?
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 03-28-2014, 06:41 AM   #5
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Pics always help.
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 03-31-2014, 01:55 PM   #6
cdt540
1983 CJ7
My rear drive shaft appears to be stuck. You should be able to slide the slip yoke back and forth by hand correct? If so I guess I have to get the yoke out so I can clean it up and grease it. Nothing tricky here, the yoke should just slide out. There are no retaining c-clips or anything like that holding the slip you to the drive shaft?
Unread 03-31-2014, 02:08 PM   #7
LumpyGrits
Yes-by hand.
LG
Unread 03-31-2014, 03:51 PM   #8
gmakra
Matt when was the last time you detailed under your Jeep its very dirty!
gmakra is offline   Reply With Quote Quick reply to this message
Unread 03-31-2014, 04:03 PM   #9
LumpyGrits
IF that is 'dirty'-I'm doomed..........
LG
Unread 03-31-2014, 04:25 PM   #10
Mike Romain
I would grease it until the grease came out the hole and then work it. The fresh grease will clean it out as most will be expelled even it compresses.
I have never seen one fall apart so I believe something holds it in place. No gotta be sure because I have filled mine with grease and it didn't come apart, the grease squirted out the overflow hole.
If you do take it apart, be real sure it goes back together with the u- joints still in line. If you go off a spline, things will bind up nasty.
Mike
Unread 03-31-2014, 04:31 PM   #11
LumpyGrits
I paint small alignment marks to be sure the shaft goes back together correctly.
LG
Unread 03-31-2014, 07:20 PM   #12
82JeepCJ7
1982 CJ7
If you run a DC, it looks like this in the rear. With the front, the slip yoke is up at the T-case end.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote Quick reply to this message
Unread 03-31-2014, 08:01 PM   #13
skizriz
1978 CJ7
I like to run mine with the slip joint down at the axle. After a losing battle with a rock, and this happening, the fix was to simply slide the yoke off at the slip joint, and slide a new yoke on. Literally a 15 minute repair job with any same sized yoke from the scrap pile.
Having it the other way would have required building an entire new drive shaft.
78 CJ7.. 258.. TH400/Dana18.. SOA/stock YJ springs.. 35" General Grabbers.. Waggy 44s.. 4.88 gears...Spartan/Lockright...Fiberglass front to rear
skizriz is online now   Reply With Quote Quick reply to this message
Unread 04-03-2014, 11:58 AM   #14
Cutlass327
Cutlass327's Avatar
1978 CJ5
Originally the slip yoke is at the top. Less chance of vibration that way, just don't ask me to explain - too hard to describe with centripetal forces, wear, etc..
As for it sliding off, there is a metal cap that holds the seal in place and has tabs that bend over the slip joint to hold it in place. The only thing holding them together is these parts. To lube them, the proper way is to grease until it comes out the little hole, then block the little hole with your finger and grease until it comes out the back of the slip joint. Good luck getting your finger in there though!
Rick
1978 CJ5 258/T177/D300, '86 D30/D44 WT axles, 'glass tub windshield frame, and fenders, 31x10.5 BFG A/T, TDK galv'd frame - DD and weekend toy
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline   Reply With Quote Quick reply to this message
Unread 04-04-2014, 02:09 PM   #15
OldCJ
1978 CJ5
Some of the original shafts have threaded collars that stop them from pulling apart. The one that Matt 1981 posted looks like that style.
OldCJ is online now   Reply With Quote Quick reply to this message
