DUI install with factory tach - JeepForum.com
post #1 of 27 Old 02-09-2009, 05:42 PM Thread Starter
jatepper
Did a search and found some information about tracing the red wire from the ignition module to supply power to the DUI.
Can someone clarify this? I looked at the module and could not tell exactly which wire to splice in to. Will my factory tach still work?
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #2 of 27 Old 02-09-2009, 06:02 PM
BioTex
1979 CJ7
Does this help?
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #3 of 27 Old 02-09-2009, 06:18 PM Thread Starter
jatepper
Well thats just the wiring diagram. Does the ignition coil postive terminal connect to power the DUI and the tach will still work? If so, I just remove from the bulkhead, splice, and have at it?
Thanks
jatepper is offline
post #4 of 27 Old 02-09-2009, 07:08 PM
jcal73
jcal73's Avatar
2015 JK Wrangler
Jatepper,
I used a relay switched from ignition power to power my DUI.
Here is a relay explanation that is from JEEPHAMMER it is his and can be a useful reference.
You would want to connect
battery to 30
Output to the DUI on 87
Ignition power on 85
Ground on 86.
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #5 of 27 Old 02-09-2009, 07:11 PM Thread Starter
jatepper
Thanks, but I was wondering how to wire the thing up so my factory tach still works.
jatepper is offline
post #6 of 27 Old 02-09-2009, 07:13 PM
jcal73
jcal73's Avatar
2015 JK Wrangler
Sorry I stupid!
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #7 of 27 Old 02-09-2009, 08:36 PM
sweetguardian00
1946 CJ2A
the signal is different, the factory AMC tach didnt work on my HEI install (it actually bobbed to the radio, go figure!)
1946 CJ-2A 225/T90/D18
1966 CJ-5 231/T86/D18
1986 CJ-7 258/TF999/D300
1984 C-10 6.2/SM465
Yeah it's a Diesel
sweetguardian00 is offline
post #8 of 27 Old 02-09-2009, 08:41 PM
BioTex
1979 CJ7
I found this from one of JH posts, I knew I read this somewhere, since I purchased a factory tach, and was trying tofigure out how to wire it. I have all that info stored on a different computer, so no access to it right now.
If you have a FACTORY TACH, you will need to trace the module 'Red' power wire back in the harness where it hooks up to a 10 Ga. wire, and splice in there.
He wrote this in a thread discussing how to wire in a DUI. The red 10Ga. wire is BW in the picture
Currently:
BioTex is offline
post #9 of 27 Old 02-09-2009, 08:47 PM Thread Starter
jatepper
EXACTLY what I was looking for. So, the DUI will get its power directly from here, correct?? And, this is located on the engine comparment side of the firewall just under the brake booster, correct??
jatepper is offline
post #10 of 27 Old 02-09-2009, 09:11 PM
BioTex
1979 CJ7
Yes, if you look inside the wire loom, you will see that wire BW is a 10 guage red. This is the wire I used to hook up my HEI.
Currently:
BioTex is offline
post #11 of 27 Old 02-10-2009, 02:52 AM
John Strenk
John Strenk's Avatar
1976 CJ5
This is the splice you are looking for:
Look for the big red wire going to the ignition module.
John Strenk is offline
post #12 of 27 Old 02-10-2009, 06:48 AM
wendell
1987 YJ Wrangler
Some of the HEI distributers on ebay come with the tach adapter and some even come with the hook up for MSD 6 or the off/road box, it's just plug and play.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #13 of 27 Old 02-10-2009, 07:19 AM
John Strenk
1976 CJ5
Make sure the Tach adapter works with sireis Tachs. Many just work with Aftermarket tachs. You can't miss hooking it up the way shown above.
post #14 of 27 Old 02-10-2009, 05:09 PM
JeepHammer
Running On Empty...
1973 CJ5
There is a power wire that comes from the ignition switch, through the bulk head fitting, and out to a number of things.
Usually, it feeds the Ignition module, Ignition coil through a resistor, and it 'Excites' the alternator so it starts charging.
If you take the two wire connector that plugs into your ignition module,
And use this gadget,
http://store.summitracing.com/partde...0&autoview=sku
You can plug your new HEI clone right into the part on the left with the Red & White wires.
This piece shown on the left plugs into the harness side of that module 2 wire connector, and will keep your factory 'Series' tach working just fine with the clone HEI's.
With this gadget, you simply unplug your module two wire connector,
Plug this thing into the harness side,
Then run a wire from the Crimp terminal at the top over to your HEI clone.
Use at least a 12 Ga. wire size, and you shouldn't have a problem with your factory Series type tach.
You will only use the part on the right, the 'SAE' plug and little connectors shouldn't be needed for your HEI clone.
John, notice that SUMMIT has a diode in their feed?
Remember the crap Dale gave me about having a diode in my 'Stealth HEI' set up?...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #15 of 27 Old 02-10-2009, 07:14 PM
John Strenk
1976 CJ5
Funny thing, I was tracing out a cheap DuraSpark module circuit board about 15 min ago and I said. "Well, they even have a diode on the board on that wire."
One of these days I'll have top draw up that circuit. I bet the OEM is way different than these cheap substitutes.
I'm going to add one onto my Stealth box also. Time I pulled out the new Digital scope out anyway.
factory tach ??? azzkikr1 Jeep CJ Forum 11 03-03-2009 02:33 PM
'75 CJ factory tach BrandyMB Jeep CJ Forum 0 12-24-2007 08:27 PM
Factory Tach basscj7 Jeep CJ Forum 11 12-10-2007 11:19 AM
HEI with factory tach??? texashighridin Jeep CJ Forum 10 01-08-2007 07:49 AM
factory tach? certifiablejeep Jeep CJ Forum 5 01-14-2003 07:54 PM
