DUI drive gear?? - JeepForum.com
post #1 of 8 Old 05-09-2013, 09:30 PM Thread Starter
geneapodaca
1978 CJ7
DUI drive gear??
After reading a few posts, I'm seeing that HEI/DUI drive gears are tearing up cam gears. Is this inherent in all HEI type distributors? Do I need to panic or at least stop driving my Jeep till I replace the distributor drive gear? I still have the old distributor so I have parts, but how necessary is it? And, why would a new distributor have a gear that's not compatible with other engine parts? I sent an email to Performance Distributors asking them the same questions but I'm thinking the Jeep forum would know more about our specific engines and issues so I'll consider the responses here more thoroughly. Thanks.
My engine is a fairly new crate 304 with a mild cam.
geneapodaca is offline
post #2 of 8 Old 05-09-2013, 09:34 PM
John N
1981 CJ8
The problem isn't with DUI brand HEI distributors. It's mainly with the cheaper HEI's that are using hardened gears.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #3 of 8 Old 05-09-2013, 10:44 PM
BagusJeep
1981 CJ7
JH had the view that DUI were better than the average but why take the risk???
The problem is that the HEI is out of a GM engine that had different specs. As stated by John it is the hardness of the gear that is a concern, if too hard it will eat the softer metal of the cam.
It is a straightforward swap between distributors.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 8 Old 05-10-2013, 05:51 AM
RDH
I don't see it spelled out clearly so I'll say it now. PUT THE DRIVE GEAR FROM YOUR OLD DISTRIBUTOR ON THE NEW ONE!
1978 CJ7: 304, 3Spd, AMC 20 Rear, Thrush Welded Mufflers W/ Turndowns, Unknown Front, Worn out Dana 20 case
RDH is offline
post #5 of 8 Old 05-10-2013, 06:50 AM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
"And, why would a new distributor have a gear that's not compatible with other engine parts?"
No NEW cam gear is compatible w/an old/used cam gear, already in your engine..
RDH said it best.
Search function "cam/dizzy gear" whoulda told ya that.
Sorry if that sounds harsh..no java yet.
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #6 of 8 Old 05-10-2013, 08:15 AM
CSP
It has nothing to do with the specs of the HEI. These hardened gears aren't the stock HEI gears. The stock HEI gears have the cut going the opposite direction as AMC gears, so they can't be used to begin with.
The problem gears are cheapo AMC V8 gears that are installed on cheapo HEI units made offshore.
CSP is offline
post #7 of 8 Old 05-10-2013, 08:20 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Has anyone had any issues with the gears that come on the re-man'd Motorcraft distributers?
Thanks,
Matt
Matt1981CJ7 is online now
post #8 of 8 Old 05-11-2013, 05:46 AM
RDH
Depends... Ford had different gear materials for different engines (ie roller vs. mechanical). Regardless, you never EVER put new gears in with old ones. This goes for axle gearing, engine gears (diesels), distributors , etc. After a TON of miles racked up, the gears wear in together making them a matched set. There's no better way to destroy a perfectly good gear and littering your oil system with metal than to install old on new.
RDH is offline
