After reading a few posts, I'm seeing that HEI/DUI drive gears are tearing up cam gears. Is this inherent in all HEI type distributors? Do I need to panic or at least stop driving my Jeep till I replace the distributor drive gear? I still have the old distributor so I have parts, but how necessary is it? And, why would a new distributor have a gear that's not compatible with other engine parts? I sent an email to Performance Distributors asking them the same questions but I'm thinking the Jeep forum would know more about our specific engines and issues so I'll consider the responses here more thoroughly. Thanks.
My engine is a fairly new crate 304 with a mild cam.
JH had the view that DUI were better than the average but why take the risk???
The problem is that the HEI is out of a GM engine that had different specs. As stated by John it is the hardness of the gear that is a concern, if too hard it will eat the softer metal of the cam.
It is a straightforward swap between distributors.
It has nothing to do with the specs of the HEI. These hardened gears aren't the stock HEI gears. The stock HEI gears have the cut going the opposite direction as AMC gears, so they can't be used to begin with.
The problem gears are cheapo AMC V8 gears that are installed on cheapo HEI units made offshore.
"And, why would a new distributor have a gear that's not compatible with other engine parts?"
No NEW cam gear is compatible w/an old/used cam gear, already in your engine..
RDH said it best.
Search function "cam/dizzy gear" whoulda told ya that.
Sorry if that sounds harsh..no java yet.
Depends... Ford had different gear materials for different engines (ie roller vs. mechanical). Regardless, you never EVER put new gears in with old ones. This goes for axle gearing, engine gears (diesels), distributors , etc. After a TON of miles racked up, the gears wear in together making them a matched set. There's no better way to destroy a perfectly good gear and littering your oil system with metal than to install old on new.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
