Dual Oil Pressure Switch? - JeepForum.com
post #1 of 5 Old 03-04-2002, 08:55 PM Thread Starter
HighCountry
Question Dual Oil Pressure Switch?
OK... On my '86 CJ-7 with the 258 (4.2) I have found TWO oil pressure sending units! One is the "big metal can" that sends the signal to the gauge, the other looks like an "idiot light" switch. Does anyone know what this extra Oil Pressure switch does?
Bruce
HighCountry is offline
post #2 of 5 Old 03-04-2002, 10:53 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Post
Are you sure the small one isn't the temp sending unit?
bazinga
jeepdaddy2000 is offline
post #3 of 5 Old 03-05-2002, 09:01 AM
OfFtHeWaLl
Post
Ya i think he is right if the little one is tword the back of your engine on the driver side its the temp sening unit.. to be shur unscrew the little one you shoud see radiator fluid in the hole if youdo thats the temp sender...
Thomas Mintz
84 CJ7
in 4cy
33 2in lift
it's my problem child
butt i love it
OfFtHeWaLl is offline
post #4 of 5 Old 03-05-2002, 09:17 AM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Post
My CJ had 2 oil pressure sending units also - Seems the P.O. had added an aftermarket gauge and instead of removing the old one, just plumbed the new sending unit into the mess. Bottom line - get rid of the extra one!
Steve
OldJeepguy is offline
post #5 of 5 Old 03-05-2002, 10:17 PM Thread Starter
HighCountry
Post
Hate to break it to you guys... Mine REALLY does have TWO units. One is the large can that operates the gauge in the dash. The other is the "on-off" switch type, and they are BOTH original equipment. There is a brass splitter screwed into the engine and both units are screwed into two holes in it. The wiring and all is definitely original and unmodified.
My NAPA parts buddy made a guess until we can get a repair manual. He thinks the "on-off" switch only allows current to the electric choke heater when there is oil pressure. Says it keeps the choke element from heating up when you just have the key in the "on" position without the engine running. I am sure the service manual will solve this mystery!
I'll let you know when I find out what it does!
Bruce
Guest Battery Selector Switch and dual batteries jatepper Jeep CJ Forum 8 11-23-2009 09:30 AM
tbi oil pressure kill switch how to 1986cj Jeep CJ Forum 1 02-02-2009 10:20 AM
oil pressure switch kjhibbs Jeep CJ Forum 3 08-15-2008 08:54 PM
Oil Pressure Switch BeesJeep Jeep CJ Forum 17 10-01-2007 06:50 AM
oil pressure switch wires go where? cjowner Jeep CJ Forum 4 09-03-2007 08:34 PM
