dual fuel tanks - Page 3 - JeepForum.com
post #31 of 36 Old 04-01-2011, 07:11 AM
chevyk30
1973 CJ5
Originally Posted by Jdgeroy View Post
I have a 74' CJ 5 with dual tanks, didn't know it wasn't standard. One tank is a 15 gallon polly, the other is below the driver's seat...best I can tell is it is 10 0r 12 gallons.
My '73 has that same thing, someone added a second tank under the driver seat, its from an older cj ('55-71'?) works good, they added the body panel from the older jeep, so it has a filler that looks just like an older jeep, plus it has the main tank in the back. I have a brass manual selector valve I found it at NAPA. I too thought it was stock until I tried to find a replacement grommet for it, called the guys at Krage motorsports and he told me that was common to do back in the '70's.
1979 CJ7 Factory installed 304 V8, T18A, Dana 20... 1999 XJ 4.0, AW4, 242..
1984 Chevy K30, 4 door, 6" lift, 36" swampers, Cummins intercooled turbo diesel, nv4500, np205, GV overdrive.
chevyk30 is offline
post #32 of 36 Old 04-21-2013, 01:03 PM
stretch66dog
1969 CJ5
I need help wiring a 6 pole, three position on-off-on toggle switch to my Stewart Warner gauge. I have duel gas tanks with also a shut off valve under the body. I getting really upset that Napa and other stores sell parts that DON'T include instructions. Thanks people.....
stretch66dog is offline
post #33 of 36 Old 04-21-2013, 01:09 PM
stretch66dog
1969 CJ5
1969 CJ5 help!
I have duel tanks but, the wiring was all jacked up. Can anyone help please. Duel tanks with a shut off valve under the body. 6 pole three position toggle switch on- off-on. going to Stewart Warner fuel gauge.
post #34 of 36 Old 04-21-2013, 01:16 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
One side of the switch will put power to the solenoid. The other side will put signal to the fuel gauge. I don't think you'd want a center off-type switch though. A dpdt switch should do it.
Center tab of gauge side gets the wire to the gauge, the one outside tab gets the wire from one tank, and the other gets the wire from the other tank. Now the tank solenoid just gets power thru the switch so that the tank that the gauge is reading will be the one supplying the fuel.
Rick
Cutlass327 is offline
post #35 of 36 Old 04-21-2013, 01:18 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Maybe Google "adding second fuel tank" or "wiring auxiliary fuel switch"...
Rick
post #36 of 36 Old 04-21-2013, 03:08 PM
stretch66dog
1969 CJ5
Wiring gas tanks
Yeah I have been doing that for several hours now. (internet) Funny how you buy Napa parts and they come with no instructions. Borg Warner FSV1Z: I have tried different ways to wire them up and I get noting. I made sure that the gauge was working bypassing the switch. GTG. When I try to use the switch noting. Diagram would really be helpful. Thanks everyone.
Howell EFI and dual tanks Kilrain Jeep CJ Forum 1 09-11-2010 11:05 PM
fuel tanks vtjeeps Jeep CJ Forum 0 11-21-2007 04:50 PM
dual gas tanks gfritzges Jeep CJ Forum 1 05-23-2006 07:16 PM
Fuel Tanks glaudde Jeep CJ Forum 2 09-11-2004 01:51 PM
Dual Gas tanks on a CJ7 CJman77 Jeep CJ Forum 12 01-31-2004 07:21 PM
