dual fuel tanks - Page 2 - JeepForum.com
post #16 of 36 Old 03-30-2011, 09:02 PM
dtcohen
1980 CJ7
I like the idea of getting one from a ford pickup that had dual tanks. probably wouldnt cost too much from NAPA, or you could try to find one in a junkyard
dtcohen is offline
post #17 of 36 Old 03-30-2011, 09:35 PM
Kilrain
1979 CJ5
Originally Posted by kickingprop View Post
Is that a manually actuate valve or is it controlled by a dash mounted switch? Thinkin that might work nicely with my Scout's dual fuel tanks...
Electrically switched.
Kilrain is offline
post #18 of 36 Old 03-30-2011, 09:45 PM Thread Starter
southernford246
1974 CJ5
thats the right number how would you wire the 2 sending units and the valve in ?
southernford246 is offline
post #19 of 36 Old 03-30-2011, 09:48 PM Thread Starter
southernford246
1974 CJ5
that is the right number
how would i wire the 2 sending units to the gauge and the valve in??
post #20 of 36 Old 03-30-2011, 11:21 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Uses a (DPDT?) switch so that the sender output would be controlled by the one side, and the solenoid power would be by the other side. Connect the gauge wire to the center terminal, and the sender outputs to the outside terminals. Then have the B+ go to the other center terminal and have the solenoid be powered when the gauge for the AUX tank is being read. I am guessing that one from NAPA is on the one tank when powered and then the other tank when not powered. I'd use the AUX tank on the powered side, that way if need be it defaults to the main tank.
Rick
Cutlass327 is offline
post #21 of 36 Old 03-31-2011, 03:33 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Here you go. Just as Cutlass Described
John Strenk is offline
post #22 of 36 Old 03-31-2011, 09:25 AM Thread Starter
southernford246
1974 CJ5
for the return line how would i run that?
post #23 of 36 Old 03-31-2011, 10:35 AM
John Strenk
1976 CJ5
Interesting, Ideally you would use another fuel switch. I wonder what they do on trucks for that. I can easy see over filling one tank if not done correctly. It would be a big surprise on day when you pull the gas cap off. I don't know if you can get away with a "T" fitting or not.
post #24 of 36 Old 03-31-2011, 10:39 AM
benullman
1981 CJ7
That's what I would do. Hook up 2 switches in tandem for the supply and return
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #25 of 36 Old 03-31-2011, 10:43 AM
joecool79
1982 CJ5
Originally Posted by benullman View Post
a second fuel tank
beat me to it. I guess I am not the only smart *** on the planet.
joecool79 is offline
post #26 of 36 Old 03-31-2011, 11:37 AM
benullman
1981 CJ7
I try when I can
post #27 of 36 Old 03-31-2011, 05:47 PM
colojeepguy
1970 CJ5
On my 70 CJ, I have the stock under seat tank (10 gallons) and a 71-75 tank (15 gallons) in the rear. I took the stock temp gauge out of the cluster & put in a second gas gauge. If you're running the return line, you can get a dual line (6 port) switching valve similar to the 3 port one pictured above. Dont run a tee in the return line-thats how mine's set up & it fills the front tank when I'm running on the rear tank.
colojeepguy is offline
post #28 of 36 Old 03-31-2011, 07:00 PM
Kilrain
1979 CJ5
Scans with diagrams, part numbers and instructions. Hope it helps.
Kilrain is offline
post #29 of 36 Old 04-01-2011, 05:28 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I have a dual set up ihn my 71. For you, install a saddle tank from a 55-71 CJ. Run both fuel and return lines to a petcock between the seats. You can use either a manual one from a late 70's Ford or an electrical one from a late 80 truck (both will have a fuel and return line, although the manual one's are rare and hard to find). I believe that a switch from a 87-97 Ford diesel will also work. As for your fuel gauge, if the switch won't flip it in tandem with the tank your using, simply mount a three pole switch next to the speedo head and lable it main and aux. Run the power wire to middle stud, the rear tank to one and the aux to the other(be sure to ground the aux tank sending unit). You will need to remember to switch the tanks both manually or the fuel gauge will not be reading the thank your running.
jeepdaddy2000 is offline
post #30 of 36 Old 04-01-2011, 06:55 AM
kickingprop
This is the manual type valve that is in my Scout 800A with dual tanks. Also an option if you dont want to mess with the wiring. The valve handle mounts up through the floor.
http://www.superscoutspecialists.com...ut-80-800.aspx
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
Howell EFI and dual tanks Kilrain Jeep CJ Forum 1 09-11-2010 11:05 PM
fuel tanks vtjeeps Jeep CJ Forum 0 11-21-2007 04:50 PM
dual gas tanks gfritzges Jeep CJ Forum 1 05-23-2006 07:16 PM
Fuel Tanks glaudde Jeep CJ Forum 2 09-11-2004 01:51 PM
Dual Gas tanks on a CJ7 CJman77 Jeep CJ Forum 12 01-31-2004 07:21 PM
