dual batterys - Page 8 - JeepForum.com
 5Likes
post #106 of 114 Old 07-28-2009, 10:29 PM
fireshadow
http://www.JunkYardGenius.com/chargi...dualbatt07.gif[/IMG]
sorry for bringing a dead thread back to life but I was wondering something, I would like to run dual batteries on my yj and don't think I need dual starting batteries since it doesn't get that cold around me, but I do plan on hooking up off road lights for fishing and running my winch when needed. I was thing a starting battery and a deep cycle for the lights and winch. I was really intrigued by this set up but wanted to see what you guys thought would be the best set up for me. Also still have stock alt. I am willing to upgrade if it is called for. This is my first dual battery set up, thanks.
1988 Jeep Wrangler, home made posi lock, team rush upgrade, motorcraft 2100 carb, warn m8000 winch, np231c front yoke, rc 2.5" lift, 1" lift shackles
Even my motorcycle has a square headlight(1984 Honda Saber)!!!
fireshadow is offline
post #107 of 114 Old 09-28-2010, 08:42 PM
genghisman
Originally Posted by JeepHammer View Post
Is it possible to do this setup on an 89 YJ with a SBC swapped in? I have a buddy that just bought an 89 YJ with a Chevy 350 ad he wants to do this.
2004-2006 - Member of 3 BSTB, 3BDE 3ID
2006-2011 - Member of the 1st BN 15IN Reg. "Can Do", 3BDE 3ID
2011-Present - Medically Retired, disabled veteran
Iraqi Freedom 3 and 5 Vet
genghisman is offline
post #108 of 114 Old 09-29-2010, 01:18 PM
mtndew1
1976 CJ7
I was inspired by this thread and finished mine.
Parts List
- Wrangler NW Dual Tray - Found open box on CL for cheap
- 2 Odyssey Batteries - one with 2 sets of top posts and one with single set
- Hellroaring Isolator
- Welding Cable in several sizes from my local shop
- Adheasive lined Shrink wrap - Thanks Jeep Hammer
- VTE Fuse Holder, Grounding Block - Terminal Insulators, Caps & Covers, Electro-Mechanical Connectors, Fuses & Fuse Holders
Pics of some of the VTE stuff.
Fuse Holder for Main Fuse and Winch Fuse
ANL Fuses
Ground Distribution
1976 Jeep CJ7 - Build in progress
mtndew1 is offline
post #109 of 114 Old 11-05-2011, 11:15 AM
OregonFXSTC
1976 CJ5
Thank you for the information in this thread and the site as a whole.
I read through several of JeepHammer's posts and other members.
I realized the least I can do for the help I have found is purchase a Premium Membership and help support the cost of keeping the lights on here.
I just did that.
Thank you for ultimately keeping my Jeep on the road running .
Mike
OregonFXSTC is offline
post #110 of 114 Old 11-06-2011, 12:57 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
JH - Pic 3 after the yellow engine bay in post #5, your relay pinouts are backwards. You have the load/power on 85/85, and the control on 30 and 87. May want to double check your diagram
Rick
Cutlass327 is online now
post #111 of 114 Old 12-24-2011, 12:44 PM
KerrMonster
1978 CJ7
I just did a Cummins 4BT swap in my 78 CJ7 and want to run dual batteries. So in terms of application, I'm running a diesel, winch, heavy off-road use, and in cold weather climates. I'd like to run your #3 configuration with the idiot light. My questions is that my diesel already has a mechanical oil pressure gauge, so I'm not sure how to incorporate the oil switch you use? Where/do I connect that oil switch? My alternator came with the diesel, so I'm assuming it's heavy enough? But I'd like your thoughts how you thinks it's best to wire my jeep.
KerrMonster is offline
post #112 of 114 Old 12-24-2011, 12:58 PM
JeepHammer
Running On Empty...
1973 CJ5
Idiot light has nothing to do with the gauge.
Idiot light is an 'On/Off' thing, stand alone from the gauge.
If you have a gauge, you will need to add a 'T' in the oil pressure source for the idiot light switch.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #113 of 114 Old 12-24-2011, 01:15 PM
JeepHammer
Running On Empty...
1973 CJ5
Long dead post, but relevant...
The dual batteries *MIGHT* not be needed for starting the engine,
BUT,
They make GREAT self rescue alternative if you isolate one of the batteries when the ignition is 'Off'...
You can only run ONE of the batteries down that way, and the other will save your butt when you do leave something turned on you shouldn't have...
Also, you won't believe how much better your starter works with that second battery, and how fast your engine snaps to life since you finally have enough current for both the starter & ignition in excess...
Second batteries are SELF RESCUE,
They are WINCH TIME DURATION DOUBLER,,
They make your starter last MUCH longer,
They help your engine jump to life when you hit the key switch,
And if you wire correctly, they are 'Lend Power' to someone on the trail,
Camp power away from the Jeep (like air mattress in your tent),
You can do simple MIG or Stick welding off them,
And they generally make things more pleasant when you don't want to get stranded.
I used to carry a second alternator for welding and emergency charging.
Having that second alternator in a CJ takes up a LOT of room and was cumbersome to use at the very least...
Now with two batteries, I can pack the alternator full of mud on the first hole in the trail and still run all day on battery power,
No second alternator needed.
In 30 seconds, I can set up to weld off the batteries with a wiring adapter and jumper cables.
I can pull a battery, drop the jumper cables and 'Lend Power' to anyone on the trail,
Or leave power back at the camp site for the battery powered appliances.
AND! I NEVER GET STUCK FOR BATTERY POWER,
The winch works MUCH better with two batteries,
The starter works MUCH better with two batteries,
The ignition works MUCH better with two batteries,
I'm NEVER stranded with a 'Dead' battery since the system isolates the second battery when the oil pressure drops (Engine shuts off) so if I leave lights, radios, ect. on, I don't kill BOTH batteries.
Since they are hard wired, one battery can be COMPLETELY dead an the vehicle will still fire up,
You can't transfer enough current with most jumper cables to do that,
You can 'BOOST' a battery that's not too far gone, but you can power the 'Dead' vehicle up from 'Scratch'...
And I don't waste any cargo room since the battery stores under the hood with NO ISSUES WHAT SO EVER...
The system is all automatic, even self rescue is the flip of a switch or the push of a button...
I can take the 'Lend Power' battery out in about 10 Seconds,
And I can be ready to weld in 30 seconds...
It's all about what YOU want your electrical system to do,
Work for you in ways you hadn't thought about before,
Or stay 'Stock'...
Doesn't matter to me either way, but I like having my system do some work other than marginally turning over the starter once in a while...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #114 of 114 Old 12-24-2011, 01:36 PM
KerrMonster
1978 CJ7
What's the benefit of running a starting battery and a deep cycle battery? I thought point of the dual battery was to pull power from both batteries that are of the same type and age?
dual batterys and alternators? petey156 Jeep CJ Forum 17 03-17-2009 09:18 PM
Dual Shocks JeffJ Jeep CJ Forum 1 12-11-2008 12:15 PM
Dual batteries in 82 CJ FIRE1 Jeep CJ Forum 5 01-11-2007 01:57 PM
dual gas tanks gfritzges Jeep CJ Forum 1 05-23-2006 07:16 PM
dual batterys jakemary Jeep CJ Forum 5 04-06-2006 08:42 PM
