dual batterys - JeepForum.com
post #1 of 6 Old 04-05-2006, 09:15 PM Thread Starter
jakemary
1977 CJ7
dual batterys
Hi how would you hook up a dual battery set up.? i have two optimun batterys in my 77cj-7 i have a ramsey12500lbs winch. a H.E.I dist. 304v8 3speed. no extra lights on the cj. a electric fan. do you run them parralle? put a switch inbetween them?
jakemary is offline
post #2 of 6 Old 04-05-2006, 10:58 PM
jeepskate
Google it. There's basic ways to do it with solenoids or isolators and there are also higher tech methods from Painless & Hellroaring that allow you more control. I have the Hellroaring setup in my CJ-7 and will probably do the same on my Scrambler when I get to that point.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 6 Old 04-06-2006, 12:18 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
my friend 'skate is right... that is a mega-question with many possible options. i chose not to use the blue box isolator set up ( a la kragens...checker, etc...) and went with a simple OEM ford style solenoid between the batteries. crude? yes. not efficient? yes. but have i ever suffered a let down winching many foos out of harms way? never...
search the web. educate ur self and get it awn...
mb
RARECJ8 is offline
post #4 of 6 Old 04-06-2006, 01:01 AM
CJ_Mike
best way is to research it and do it the way you want. i have my battery in the engine compartment running engine and accessories and my rear battery running the winch and also going to a power board so that if i ever get stuff that needs power ill just run the positave there to keep it cleaner. and also i have another solenoid hooked up to a dash switch that connects the two battery circuits so if my front battery dies, flip the switch and hopefully i should have enough power to get it to crank over. but luckly i havent had to use it but considering both batteries less that 6 months old, i wont have to for a while.
CJ_Mike is offline
post #5 of 6 Old 04-06-2006, 08:39 AM
401ton
I run a www.12voltguy.com solenoid system.
It will work normal, charge both batteries and self jump start modes.
System has a solenoid simliar to a Ford starter, but it is rated higher.
Works great.
His was a comeplete system including cables and less expensive than most.
I don't run anything off the second battery except the wire to solenoid to self jump start.
AMC 401, Howell TBI, NP-435, Atlas 4.3, Rockcrusher 60, Shaved 14 bolt, 110" WB, Stazworks Double Beadlocks and 42's...
401ton is offline
post #6 of 6 Old 04-06-2006, 08:42 PM Thread Starter
jakemary
1977 CJ7
thanks guys
jakemary is offline
dual batterys petey156 Jeep CJ Forum 113 12-24-2011 01:36 PM
dual batterys and alternators? petey156 Jeep CJ Forum 17 03-17-2009 09:18 PM
Dual Shocks JeffJ Jeep CJ Forum 1 12-11-2008 12:15 PM
Dual batteries in 82 CJ FIRE1 Jeep CJ Forum 5 01-11-2007 01:57 PM
dual gas tanks gfritzges Jeep CJ Forum 1 05-23-2006 07:16 PM
