Dual Battery Isolator or Solenoid? - Page 4 - JeepForum.com
post #46 of 124 Old 10-24-2013, 08:48 AM
wj4play
Originally Posted by Matt1981CJ7
Mornin' gentlemen,
Here's the final install. I took Hubs advice and used nylocks on the top post terminals. I also installed the 150 amp fuse (just right of the isolator) for some added protection. Lastly, I re-routed the winch cable and accessory wiring to the side terminals of the main battery, which tidied the wiring up a little more.
Unfortunately, the LED light on the remote switch was no good. The switch worked but the little indicator LED didn't. Hellroaring is sending be another switch.
I tested the system and all seems well. In "automatic" mode (both batteries get charged but the backup is isolated from loads), with the engine at high idle, both batteries are showing 14.58 volts. At normal idle they show 14.28 volts. So the alternator and isolator are both doing their jobs.
Matt
I would caution using the side terminals because in the case they are only feed by a thin metal strip (per jpmagazine article) they say use the top lugs for heavy draw accessories
Looks clean and tidy though
Sent from busted up iPhone
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #47 of 124 Old 10-24-2013, 09:09 AM Thread Starter
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
That's good to know, thanks. I'll move the winch back to the top post.
Matt1981CJ7 is offline
post #48 of 124 Old 10-24-2013, 11:54 AM
Spieg8
1984 CJ8
Looks really nice Matt. Just curious though... Were you unable to find #2 welding cable with red insolation?
Spieg8 is offline
post #49 of 124 Old 10-24-2013, 12:09 PM
lucdog
lucdog's Avatar
1980 CJ5
I would agree with this Matt.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #50 of 124 Old 10-24-2013, 04:33 PM
turbogus
1978 CJ5
I really like the idea of fabbing up a tray so things can be just as we want 'em. I may go this route when I finalize my various setups. 'Black Betty' had an oddly configured tray when I got 'er that also supports the weight of the batteries forward, mounted to the inner fender.
It's been rock solid stable since installing the 2nd battery, and using a Stinger SGP solenoid way, there's been no issues with charging, after I got the fan wiring correct.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #51 of 124 Old 10-24-2013, 06:00 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Originally Posted by WSS View Post
Stick a star washer under the wingnut if you feel they may loosen but dry cells don't expand and contract as much as wet celled batts.
'Tis not the battery proper you need to worry about - it's the post.
Doesn't matter what the chemistry/construction of the battery, "current flow" = "conductor heat." More current? More heat.
Heat-cycling the post is what causes the fasteners to loosen.
Me? I'd use a half-height nut (usually sold as a "Jam Nut" at the local) to retain any lugs, then run the wing nut down overtop of it. Jammed nuts hold FAR better than star washers, and are generally much easier to remove than Nylocks (considering you can do them with fingers, if you don't get stupid.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #52 of 124 Old 10-24-2013, 08:09 PM
WSS
WSS's Avatar
1972 CJ5
Sorry bud, missed it completely. I assumed we were talking about the battery proper and the hold down.
My bad
WSS
If you are a Purist, don't click here:
My CJ5 Build and fun stuff:
WSS is offline
post #53 of 124 Old 11-12-2013, 12:16 PM
WSS
WSS's Avatar
1972 CJ5
I am back at it. I tried to return the NOCO isolator I had purchased and literally lost the reciept on the way. Well, if it does not work as hoped, it is only a $60 mistake, easy enough to replace with a HR I/C kit later if need be. I will follow up on my buld thread but for now, this is were I am:
WSS is offline
post #54 of 124 Old 11-12-2013, 12:51 PM Thread Starter
Matt1981CJ7
1981 CJ7
Show off....
As usual WSS your work is TOP NOTCH!!
I bent the lips on my tray with a hammer and anvil.....
Matt
post #55 of 124 Old 11-12-2013, 02:54 PM
WSS
WSS's Avatar
1972 CJ5
Thanks Matt! That swag finger brake has done some pretty neat stuff for me lately, mostly boring/paying jobs but this was too easy. I usually stick it under my 100 ton press and bend 1/4" plus stuff but this 14ga was too thin for the press due to it nor even noticing it was bending anything. So I gave my arbor press a try, perfect! Probably good to 1/8"
or 12ga with just some even pull pressure. I was surprised actually how easy it bent. I am going out this weekend so I won't get so deep that I'm not ready but the old tray will have to be removed, this one needs to slide toward the engine at least an inch.
Cheers!
PS, I'll post the drawing after it is all welded (double checked).
WSS is offline
post #56 of 124 Old 11-12-2013, 05:33 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
I use a combination Marine battery switch, installed with two heavy rectifiers (diodes capable of handling high amperage loads).. the diodes split the charge circuit from your alternator, they protect against back feed when batteries and loads aren't balanced.. always better to match your batteries, but with that said, you cannot control the inner workings of those batteries for ever.. they change, so that's what one of the jobs of the diodes is, battery isolation.. the switch gives you the opportunity to use both in parallel, doubling your amperage when needed, switch A & B (reverse).. shut both off, and so on..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #57 of 124 Old 11-12-2013, 07:23 PM
EgulAye
1980 CJ5
Originally Posted by frhrwa View Post
I use a combination Marine battery switch, ...
Got a model number or brand on that? It would speed up my research a lot. Thanks...
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #58 of 124 Old 11-12-2013, 07:37 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
I would if I were home yet, but just got back to Las Vegas from Europe for the past 2 1/2 months.. headed home Saturday and I can post the make and model number.. I believe I've seen them at WalMart, but for sure at any Marine store..
frhrwa is offline
post #59 of 124 Old 11-12-2013, 07:52 PM
EgulAye
1980 CJ5
Hmm, perhaps easier to find than I thought then. Thanks for the fast response.
2012 JK
EgulAye is offline
post #60 of 124 Old 11-12-2013, 07:57 PM Thread Starter
Matt1981CJ7
1981 CJ7
It sounds like your setup works similar to the Hellroaring Isolator/combiner that I used.
EgulAye, if you haven't checked them out already, you should. I've been very impressed with the Hellroaring product.
Matt
