Dual batteries in 82 CJ - JeepForum.com
post #1 of 6 Old 01-10-2007, 02:18 PM Thread Starter
FIRE1
Just looking for some kind of plans for hooking up dual batteries in the CJ as I'm running the extra offroad lights and winch now and want to ensure that I have enough power - as of now I have the 258, 2 off road lights and an unhooked up 8000 lb winch. Any pointers especially schematics or diagrams would be great.
Thanks in advance Mark
FIRE1 is offline
post #2 of 6 Old 01-10-2007, 06:57 PM
jeepskate
I'd upgrade the alternator & wiring first, then see if you really need the extra battery. The lights generally don't draw much juice other than when you fire them up initially.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 6 Old 01-10-2007, 08:58 PM
mattmosman
I used two red top optima's and put them vertically in the battery tray..than added a couple of pieces of steel to connect the terminals...works like a charm
mattmosman is offline
post #4 of 6 Old 01-10-2007, 10:35 PM
jeepskate
You should use an isolator at the very least so that the batteries charge properly. There's also more sophisticated 'management' setups out there like from Painless and Hellroaring. There's plenty of information if you Google it...this is an *ancient* mod used by all sorts of vehicles even boats.
post #5 of 6 Old 01-11-2007, 02:01 PM
1984CJ
1984CJ's Avatar
Try perusing some of the links on this page. http://www.geocities.com/cantwait_fo...al.html#blower
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline
post #6 of 6 Old 01-11-2007, 02:57 PM
YeloCJ
[IMG][/IMG]
Here's my set up. I built my own battery tray using the stock braces and mounting bolts on the firewall.
YeloCJ, 360, 36's and Detroits f/r, T-18, Tera-low 20
YeloCJ is offline
Guest Battery Selector Switch and dual batteries jatepper Jeep CJ Forum 8 11-23-2009 10:30 AM
My CJ eats batteries! sally77cj7 Jeep CJ Forum 26 04-04-2008 09:20 PM
Dual Batteries & H.P. Alternator 8679cjs Jeep CJ Forum 5 08-08-2007 12:46 AM
Golf Cart Batteries thiswebs4u Jeep CJ Forum 1 04-06-2006 12:29 AM
Dual Batteries CJ7Jeff Jeep CJ Forum 1 05-16-2002 11:26 AM
