Drums to Disc question - JeepForum.com
post #1 of 7 Old 08-09-2003, 04:28 PM Thread Starter
Sandman74
I want to change the front drums on my 76cj7 to disc brakes. I don't mind spending money on new parts but I dont want to spend 900 on a conversion kit. How do I do this? The more specific the better. Thanks.
Youth and talent is no replacement for age and treachery.
Sandman74 is offline
post #2 of 7 Old 08-09-2003, 06:34 PM
motoxxxguy
1995 XJ Cherokee
To start, you'll need a new master cylinder, and if you don't have power brakes now, you might as well go ahead and add that too. The easiest way to do the dics swap would probably be to find a front axle in a junkyard and use the whole disc brake spindle and hub assembly from the ball joint out. It should be a fairly straight-forward swap, but could end up costing as much as a bolt-on conversion kit if you run into problems or can't find a used axle cheap.
-moto
motoxxxguy is offline
post #3 of 7 Old 08-10-2003, 09:15 AM
CSP
A new master cylinder is not necessary. The existing cylinder can easily be modified to work with discs on the front. Remove the line going to the front brakes. Look inside the hole and you'll see a brass cone (brake line seat actually). Thread a sheetmetal screw just large enough to fit in the inner hole of this cone and very carefully remove it. Behind that cone is a rubber piece and a spring. Remove both of them. This is the residual pressure valve which you don't want anymore. Insert the brass cone and thread the front line back into the master.
I've done several disc conversion and I use Chevy Dana 44 calipers and caliper mounting stands. They bolt right up to a CJ Dana 30 with some grinding of the knuckle to allow the caliper to slide. For rotors I use '76-mid 78 CJ rotors and new disc brake lug studs. I believe there are several conversion articles on the web. Try a Google search. It sure beats one of those overpriced conversion kits which use the exact same parts you can get at an auto parts store.
CSP is offline
post #4 of 7 Old 08-11-2003, 07:49 PM
rustyCJ
i just parted out 3 dana 30s with discs and have the parts for two complete disc conversions. if interested in anything let me know.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #5 of 7 Old 08-11-2003, 10:45 PM
mad_scientist
I've heard of using 91-92 GM (chevy) fullsize truck rear calipers and I believe jeep front rotors. The rest seems vague to me right now
. . . end transmission . . .
mad_scientist is offline
post #6 of 7 Old 08-12-2003, 11:13 AM
CSP
Those calipers would be kinda hard to find since no Chevy trucks in '91-92 had rear disc brakes.
CSP is offline
post #7 of 7 Old 08-12-2003, 10:27 PM
eight
eight's Avatar
I also have a disc brake setup from a D30, but the rotors need replacing. I'll send you whatever you need, cheap. Probably best to get new calipers too. I have the complete axle minus shafts.
eight is offline
77 CJ 5 Disc brake question billyroy Jeep CJ Forum 9 07-22-2013 03:30 AM
Model 20 drums to disc. conversion cadesertjp Jeep CJ Forum 6 04-28-2009 08:13 AM
How hard is it to replace rear drums with disc brakes? part.changer Jeep CJ Forum 7 06-11-2007 12:32 PM
Disc brake conversion question AvyZJDriver Jeep CJ Forum 1 12-18-2005 10:40 AM
clutch disc question tera1298 Jeep CJ Forum 1 07-18-2003 04:23 PM
