Drum To Disc Brake Conversion 68 Cj5 - JeepForum.com
post #1 of 6 Old 05-25-2007, 06:17 PM Thread Starter
dstrebor
Looking for a conversion kit to change my front brakes from drum to disc. Found plenty out there for the 1970 with the dana 30 but can't seem to locate a kit identified for the Dana 27. Will the Dana 30 kit fit the 27?
Thanks for your time folks.
R/
Dave
San Diego
dstrebor is offline
post #2 of 6 Old 05-25-2007, 07:45 PM
74_jeep
74_jeep's Avatar
1974 CJ5
You can go this route , works pretty nice .
http://www.earlycj5.com/tech/brakes/...conversion.php
74_jeep is offline
post #3 of 6 Old 05-25-2007, 07:47 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
1970 is a D27, not D30. Passenger side D30 differential was used from '72 through '86, with disc brakes added in '77 and changes to the hub made around 1980ish. The D27 uses a 6 bolt pattern for the backing plate that is the same as the '77-'78ish 6 bolt CJ caliper bracket. After that, they used a 2 bolt bracket.
You could do the Chevy swap:
EDIT: Looks like we were typing at the same time.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #4 of 6 Old 05-25-2007, 08:02 PM
74_jeep
74_jeep's Avatar
1974 CJ5
Yep,
almost beat me to it
Its a pretty good swap I done it on my Dana 30
74_jeep is offline
post #5 of 6 Old 05-25-2007, 08:31 PM Thread Starter
dstrebor
Thanks Folks. Done deal.
dstrebor is offline
post #6 of 6 Old 05-26-2007, 12:37 AM
cj7jeeps
JP did a good write up on this here is the link
http://www.jpmagazine.com/techarticl...ke_conversion/
cj7jeeps is offline
Drum to disc brake conversion for dana 25 Lifesgoodhere Jeep CJ Forum 25 12-29-2010 02:00 PM
'77 CJ7 Drum to Disc Conversion Rupie25 Jeep CJ Forum 10 10-17-2009 01:20 PM
Waggy Rear Drum To Disc Conversion Military Jeeper Jeep CJ Forum 3 03-19-2008 10:31 PM
drum\disc brake line? dragracer1199 Jeep CJ Forum 7 02-02-2008 07:55 AM
dana 30 front drum to disc conversion certifiablejeep Jeep CJ Forum 9 06-27-2004 08:10 PM
