#1 | |
dropped pitman on SOA
Can anyone offer advice on using a dropped pitman arm with a Spring over setup? I was going to go this route, but someone told me bumpsteer and handling were awful. They said the only way to drive it on road comfortably was with high steer. Any thoughts? High steer is way more $$ than a dropped pitman arm., but i want it to still drive well on the road.
#2 | |
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed. |
#3 |
Mine is a 76 so it doesn't have swaybars. I will be running fresh(er) 5 leaf wrangler springs in front which will hopefully be a little stiffer than the worn out ones I was using. Bushing will be new as well.
#4 |
I have run dropped pitmans for years; they typically improve (reduce/eliminate) bump steer.
Bump steer happens when the drag link is at an angle instead of parallel to the tie rod. When you drive over a bump with one tire the angled linkage casues the tires to turn slightly; this is bump steer. The dropped pitman reduces this angle, thus reducing bump steer. High steer has the advantage of moving your linkage to the top of the knuckles where it is much less likely to get bent from a close encounter with rocks. Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway. Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
