Dropped a piece of grommet in my 304! - JeepForum.com
post #1 of 13 Old 10-18-2009, 12:38 PM Thread Starter
scottymac62
1979 CJ7
I was installing a new PCV and grommet in my 304 yesterday and in the process of removing the old grommet (which was as hard as a brick) a large piece fell down in the hole, and I was unable to retrieve it. I need to know if the this will cause a problem if I run the engine or did it probably just fall into the oil pan? Thanks
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #2 of 13 Old 10-18-2009, 01:07 PM
TBrock
pull the valve cover and get it out of there. That's easier than rebuilding the engine.
Default Jeeper #68
MilitaryJeeper.com
TBrock is offline
post #3 of 13 Old 10-18-2009, 01:34 PM
JeepnBlake
the grommet at the far back by the fire wall on the intake?
if so there is a metal u shaped piece that goes right under the intake, and that should catch it, but its fairly easy to remove the intake.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #4 of 13 Old 10-18-2009, 01:45 PM
Jeepwine
1979 CJ5
Just leave it... It's now just setting on intake valley pan and will not hurt
a thing.
Don
Jeepwine is offline
post #5 of 13 Old 10-18-2009, 02:01 PM
73jeep
1973 CJ5
a thing.
NO you definitely want to get it out!
Can you still see it?
73jeep is offline
post #6 of 13 Old 10-18-2009, 02:31 PM
Unbalanced
Agreed, pull that sucker oughtta there.
If it was that rock hard, then it could easily get stuck in the oil return. Might not ever make it to the pan.
Better safe than sorry.
2003 TJ
2012 Overland
"Temporarily Detained" maybe, but ~never~ stuck...
Unbalanced is offline
post #7 of 13 Old 10-18-2009, 02:56 PM
Jeepwine
1979 CJ5
It will not do a dam thing... It's just setting there... But you could spend money and some time and make all these other guys happy
Don
Jeepwine is offline
post #8 of 13 Old 10-18-2009, 07:59 PM
trail58
1958 CJ5
Better safe than sorry. I'd pull the valve cover, get it out, and drive with confidence. If it's not there, it may have gone as far as the oil pan. Pull the pan, get it out, and drive with confidence.
1958 Willys CJ5 on a 71 Jeep CJ5 chassis, 231 Buick, Dana 30 front, Dana 44 rear, lockers, 5.38 on 33" tires.
trail58 is offline
post #9 of 13 Old 10-18-2009, 09:11 PM
TBrock
Odds are, you're right. However, it's my luck that it'd wind getting ingested and ground to crap and then trash every bearing in the engine. But that's my luck; his may be better...
Default Jeeper #68
MilitaryJeeper.com
TBrock is offline
post #10 of 13 Old 10-18-2009, 09:59 PM Thread Starter
scottymac62
1979 CJ7
It is the PCV that is in the back of the intake manifold. I might be able to get my shop vac to get in there at suck it out. I'll give that a try tomorrow. I really don't feel comfortable by allowing it to stay in there. Thanks for all of your inputs guys.
post #11 of 13 Old 10-19-2009, 11:42 AM
Hybrid Jeep
1976 CJ5
The piece is probably stuck on the intake valley heat shield. Don't start the Jeep, pull the intake and grab it out of there. You are only out the cost of RTV to seal up the intake again. You really SHOULD replace the stock valley pan gasket too...
If you start the motor it could go anywhere...
Hybrid Jeep is offline
post #12 of 13 Old 10-19-2009, 12:37 PM
Dad03
1975 CJ5
If its a stock intake it probably has that small heat sheild riveted on the underside of the intake. He could not get to it without removing this first even if he did pull the intake. And if it is there the grommet won't fall onto the Valley pan.
Using a straw (or something straight) see how far into the intake from the PCV port it goes in. If its a few inches you have that heat sheild in place and the grommet isn't going anywhere, unless it gets sucked up back into the carb. Try the shop vac to suck it out. If it is more than you are hitting the vally pan and you should pull the intake to go after the grommet.
Dad03 is offline
post #13 of 13 Old 10-19-2009, 12:46 PM
JeepHammer
Running On Empty...
1973 CJ5
Don't sweat it, rubber won't hurt a thing rattling around under the valve cover in an I-6 or on the valley pan of a V-8.
If the engine is very old, there are many worse things in there than a little piece of rubber!
You wouldn't believe the stuff I've found in engines when we tore them down after many miles of use.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
2 piece to 1 piece AMC20 axle swap question Robb Kiker Jeep CJ Forum 11 11-17-2009 09:01 PM
Brake Booster Grommet for the CJ Firewall? CopperCJ7 Jeep CJ Forum 12 12-17-2008 07:04 AM
Bushing/ Grommet? JeffJ Jeep CJ Forum 1 12-05-2008 07:11 AM
dropped pitman on SOA jollyroger Jeep CJ Forum 3 04-23-2008 09:51 AM
Here's a fun dumb question. (PCV valve/grommet) Swampwalker3 Jeep CJ Forum 11 03-25-2008 06:42 PM
