Dropped bolt into Engine!?!? Please Advise - JeepForum.com
post #1 of 42 Old 12-22-2009, 07:37 PM Thread Starter
Renegade578
1981 CJ7
Okay this may sound really stupid, but this is what happened. I was replacing the mechanical fuel pump on my 258. After removing the old one, I screwed the bolts back in so I would not lose them. When I got back with the new pump, I was unscrewing the bolts and one slipped out of my hand and fell into the engine. I heard it bounce around a bit before it came to rest. I believe that it is in the oil pan. I tried fishing it out with a magnet on a flexible rod with no luck. I am trying to avoid having to drop the oil pan to retrieve it.
Am I crazy to consider leaving it in there until I can get around to dropping the oil pan? Is there anything in the bottom of the oil pan that it could damage? Any thoughts?
Renegade578 is offline
post #2 of 42 Old 12-22-2009, 08:04 PM
-AC-
1977 CJ5
You're 98% safe leaving it down there. It's that other 2% that ALWAYS comes back to haunt me...
"Damn Everything But The Circus..." e.e.c.
-AC- is offline
post #3 of 42 Old 12-22-2009, 08:10 PM
_Kyle_
_Kyle_'s Avatar
If it's in the oil pan, it should be ok, but I wouldn't bet on it and would personally get it ASAP.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #4 of 42 Old 12-22-2009, 08:41 PM
KMD
1976 CJ7
try a magnet through the drain plug hole in the oil pan.Also a big speaker magnet or other strong magnet on the outside of the pan to get the bolt near the drain plug hole.
KMD is offline
post #5 of 42 Old 12-22-2009, 08:44 PM
mcurcio1989
1976 CJ7
I definitely would not feel comfortable with it down there. It takes maybe an hour to pull the pan and get it back in. Replace the gasket and what not while your down there. Plus you'll get a really good oil change. If for some reason it does find its way off the bottom of the oil pan you'll be looking at way more time to fix the problems that could cause.
Disregard everything i say
I have a dana 30 front axle and amc 20 rear if anyone is looking. Both are 3.54, drums, narrowtrack.
mcurcio1989 is offline
post #6 of 42 Old 12-22-2009, 08:47 PM
TheDustMan
I'm a YJ guy, yeah but I think this sort of thing applies to all engines. Get it out, ASAP. A bolt of any size will wreak havoc on your internals if the crankshaft picks it up somehow. Sure, you may be able to get away with it but its like playing Russian Roulette. Do you want to chance blowing the guts out of your motor?
TheDustMan is offline
post #7 of 42 Old 12-22-2009, 08:51 PM
Jeepfreak81
Jeepfreak81's Avatar
NEVER run an engine with something like that in the oil pan. Unless you need an excuse to get a new engine, IE a 4.7 Stroker....
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #8 of 42 Old 12-22-2009, 09:15 PM
southshore30
1982 CJ7
It's not installed in the vehicle is it? if it fell down the fuel pump hole the engine must have been on its side in a engine stand. pull the oil pan!
southshore30 is offline
post #9 of 42 Old 12-22-2009, 09:26 PM Thread Starter
Renegade578
1981 CJ7
The engine is installed in the vehicle. The chances of it actually falling in the engine were extremely slim, but you know Murphy's Law. That is even more reason to drop the pan. Thanks for talking my senses back into me.
post #10 of 42 Old 12-23-2009, 10:00 PM
sanddrag
All it would take is one good bump for it to bounce up off the bottom of the pan, and potentially jam between a connecting rod and the block. That would not be a good day. Better to get it out, and while you've got the pan off, clean out any sludge and inspect everything down there.
sanddrag is offline
post #11 of 42 Old 12-23-2009, 10:04 PM
billymac4511
I like the suggestion of using a speaker magnet on the outside of the pan and a magnet on a rod to pull it out of the pan.
I think that would work the best and would probably be quicker... or at least cleaner than R&R the whole oil pan... now if your gasket down there is in need of a change... what better an excuse!
Webmaster and official do-gooder of interwebbish thinggies at
Also guilty for the plague, broken egg yolks and the spork.
billymac4511 is offline
post #12 of 42 Old 12-28-2009, 03:26 PM Thread Starter
Renegade578
1981 CJ7
So my friend and I pulled an all nighter over the weekend dropping the pan. The bolt has been retrieved!! I have run into a problem though. After 6 hours of work we finally got everything put back together and the Jeep will not start. I turn the key and get nothing, not even lights. So I charged the battery this morning and took it to Autozone to load test. They say the battery is still good. I put the battery back and the Jeep and tried to start it again. The first try the solenoid clicked once but the engine did not turn over. After that I got nothing. We did have to remove the starter to drop the pan. When I get home from work I am going to check all my connections from the battery to the solenoid to the starter. Any other ideas of what might be wrong? I have not checked any fuses yet....
post #13 of 42 Old 12-28-2009, 03:28 PM
TheDustMan
Good to hear the bolt has been removed, lord knows that pesky thing could have done some real damage!
Definitely check and CLEAN the connections. What may look like just a little bit of corrosion to you could be a very high amount of resistance to the connections. Especially if you had them apart. Clean the connections on the battery too, use one of those little wire brushes for cleaning battery posts. They work awesome.
post #14 of 42 Old 12-28-2009, 05:03 PM
wm69
My Jeep was doing that and it was a bad ground. Check your neg cable where it connects to the block, and check the terminal end too. I actually ran my - batt cable to one of the ears on the starter, then another off of the other starter ear to the stock location on the block.
wm69 is offline
post #15 of 42 Old 12-28-2009, 06:12 PM
IDK
If it was me I'd just drop the pan and figure it out because any loose metal particles inside a motor will almost always end in a sad story if you try to run it. The cost of a new motor is not very appealing to me and I'd much rather go through the pain of dropping the pan and fishing it out rather than coughing up 3k for a new motor.
JpThang
IDK is offline
Help! looking for a complete engine bolt kit Jarratt Jeep CJ Forum 3 12-02-2009 06:34 AM
engine bolt size Indy Jeep CJ Forum 6 03-05-2007 03:38 PM
my 86 and engine trouble....please advise moloss Jeep CJ Forum 4 06-18-2006 08:47 AM
what torque to bolt engine to tranny hoodedrat Jeep CJ Forum 2 03-26-2004 05:44 PM
