droped pitman arm - JeepForum.com
post #1 of 5 Old 03-26-2003, 08:44 PM Thread Starter
mean green
droped pitman arm
does anyone know if they make a 4-6" droped pitman arm and where to get one. i can only find one's for 3-4" lifts i need to find some that will work for me
1985 cj-7,256, t-176,dana 300, dana 44's f & R ,detroit lockers f&r, 4.09 gears, soa with 4"suspension lift,2" shackle extention,shackle reversal,custom 3"x5" straight frame, custom roll cage with tire rack above, fiberglass body,35"s.s boggers,ramsey 8000lb winch
mean green is offline
post #2 of 5 Old 03-27-2003, 07:21 AM
Jeep Daddy
Jeep Daddy's Avatar
Never heard of one but most people with that hi a lift install something called a Hi-Steer system. I'm not sure exactly what that is because I've had no need to look into it but I imagine it's components from another vehicle that you adapt to you CJ for that large a lift.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #3 of 5 Old 03-27-2003, 08:48 AM
rustyCJ
you will not find an aftermarket dropped arm that long because if you lift your vehicle that much you gonna have big tires and the force needed to turn them would bend/break the arm.
we are talking bout 4-6"s of suspension lift right? not 3 of suspension and 3 of body or something like that? since you are in the CJ forum asking this i will assume you have done a spring over because unless you have had custom springs made there is no lift kit over 4"s for cjs. you need to do some searches with yahoo or google for "jeep SOA steering", "jeep spring over axle steering", "jeep hi-steer", "jeep cross-over steering", etc. there are hundreds of do-it-yourselfers sites out there that have information regarding this on them. i think even jeeptech.com has an article on this.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #4 of 5 Old 03-27-2003, 09:46 AM
Brandon Miller
run a flat wagoneer arm - and go hi-steer..
Brandon Miller
President of RCRC 4wd Club, Sacramento, CA
1993 ZJ. Rusty's BB and 30's. Otherwise stock. Yota with HD HP 44/60, 5.0/435/dual tcases etc etc.
Brandon Miller is offline
post #5 of 5 Old 03-27-2003, 08:12 PM Thread Starter
mean green
pitman arm
thank you all i found one that works for 4-6" of lift i pick it up tomorrow i will post what is out of or for but it is supposed to work. i have some crazy lift almost 2 ft. over stock soa,custom frame 2" taller than stock, 1" shackle , 2" body,35" tires so somewhere around 3" there it's real insane but fun
Pitman arm NWA_CJ7 Jeep CJ Forum 8 08-23-2010 10:07 PM
J10 pitman arm?? 78treehugger Jeep CJ Forum 8 04-29-2009 03:11 PM
Pitman Arm LTEJ Jeep CJ Forum 4 11-04-2008 10:24 AM
pitman arm / tie rod Aquafina Jeep CJ Forum 5 10-01-2005 04:45 PM
Yj to Cj pitman arm? lookin4mud Jeep CJ Forum 3 04-19-2005 01:36 PM
